Shock covers, an interesting solution?
Started by Wabbitkilla, August 25, 2013, 07:26
OK it's not for me, I don't have a problem.
But I seem to remember one or two people having problems where the bellows covers of their shock absorbers have failed and not people have been challenging them. The Toyota ones are expensive, and the rears come attached to the top mounts.
I've just been looking at spares for my BC coilovers and realised that theirs might fit the standard shocks and they're pretty cheap. It might be worth someone giving them a try?  m http://www.bc-racing.co.uk/accessories.html m
redarrow
I am doing the front shocks know what ones you
Think will fit the front shocks, well worth
A shot.
Grate find cheers
Regards john
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
minimike
Did anyone try these?
I am tempted but had a quick look at the OEM ones yesterday on the car and they seem to have a large rubber bit attached at the top?
My drivers side is in two bits.  s:( :( s:(
Mike.
2006 red, 2006 silver TF212, 2003 black, 2001 black
It was only an idea, you could cut the bump stops off the originals and reuse them or look for something similar on eBay.
minimike
£23 each for the OEM's.
£18 incl. postage for two BC's which might not fit.........
Bit the bullet and ordered a couple of Toyota ones off Chris. One of mine isn't split so might get a few quid back for that one, or just be able to help a member out/keep for spare.
A bit of an OCD man (aren't we all) so will have to change both!!!!!
Mike.
Andys-N20
I would play it safe and get OEM's
204.2 BHP Silver 2000 MR2, 2006 2ZZ engine, Apexi PFC, Zorstec full stainless system exhaust (including 400 cell cat & race header), titanium heat wrap, MRW underdrive pulleys, handmade short ram intake, Hondata intake gasket, Celica gearbox ratio's, LSD.
Edge 306 speakers, Alpine CDE 235BT, sound deadened doors.
Full facelift conversion including bracing, sub frame, the works...
I'd say that the BC option is a jolly good one. Many people have the shredded boots and the OEM ones are daft prices for what they are. We modify so many bits on these cars, I can't see why these wouldn't be a great thing to try.
redarrow
The idea is grate but the shipping cost i dont like
I can send one caliper for £3.50 and there no
Way there that heavy.
I wonder if there consider me sending a
Courier pick a pair up.
Ill phone them today and see.
Update if you pay via paypal over the phone
Then you can get your own courier to
Colect them.
Now i need to no what ones to get for the front
Struts, i no there need alteration but
What ones would you get to do the job?
minimike
I guess the front ones with the large hole?
Whilst on Spyder chat I found a similar thread and some of the guys over there had problems with after market boots being to wide. This meant that they got stuck in the spring and didn't work. They weren't BC ones but similar I think. Might be worth asking what diameter they are ad measuring your own springs. I think OEM springs were ok, but a guy who had after market springs fitted had problems.........
redarrow
All i need to no then, are bc springs the same
Diameter from spring to damper, as the
Standard spring?
Anybody who got the bc spring setup please
Help.
Regards john .
