Bolt for tte style chassis brace
Started by Flipside, August 25, 2013, 17:27
Flipside
Does anyone have a spare of these, from the front brace location. The thread is knackered on this one.
Also in the back corner one of the bolts sheered off, what's the best process to fix it?
2001 low mileage, mods: K&N 57i gen 2, toyosports manifold and Cobra twin exhaust, unichip. Colour coded side vents and spoiler.  not forgetting the ICE Install, stock sony head unit, sony xa300 aux input, bluetooth connection, 4 channel hertz digital amp, 2 channel hertz ep2 amp, mb quart components, hertz 10" subwoofer in the bins and UD JL 6.5 in sub. Boom!
chimpman
one of these fellas ought to do the trick.  m http://www.screwfix.com/p/screw-extract ... -set/18643 m
make sure you make a little center punch mark to stop the drill slipping and id use a carbide type drill bit, in case the bolt is a harder steel.
2005 Chilli Red. Mods.... Pine magic tree
Flipside
Thanks will give that a go
