Eml problem
Started by Paulm280885, October 23, 2013, 19:49
Paulm280885
Hey guys I fitted Nathan ultimate gear bushings today went well apart from the few cuts and bruises problem is my eml has come knw is it because I disconnected the sensor on the air intake and forgot to reconnect before starting her up do I need to disconnect batt to reset ecu ?
Most very likely. Disconnect the batt for a bit and then reconnect and everything should be good
Paulm280885
Ok thanks mate I'll do that tomoz
MattPerformance
I can reset it for you on Sat, but if you started it with the MAF sensor disconnected this will definitely put the EML on.
Paulm280885
Yeah I did start it then it cut out and I realised it was connected
Paulm280885
Hey guys
Did a 20 mile trip over to my pals today and on the way back my eml cam on again what do you think it could be latest mods
New exhaust with sports cat
Markiii pipe
Nathan gear bushings
And also had to disconnect the maf to install the gear bushing  but I've since disconnected the batt to reset ecu what got rid of the light but knw it back
Any help please guys .
Rather than randomly guessing, the easiest answer is -  l viewtopic.php?f=11&t=16017 l    s:D :D s:D
(it's definitely not the gear bushings though)
Paulm280885
Ok thanks mate bought one last night of ebay. No problems with the car running like a dream
nathanMR2
Ill put money its the sports cat if youve had no spacer put in between the O2 sensor.
Failing that its likely to be a failed O2 sensor. You really need to get the code read
Paulm280885
Cheers Nath I'm thinking it's the sports cat aswell code reader should be here tomoz do you think it's ok to drive it ?
nathanMR2
Shouldnt be a problem if its either one of the things ive mentioned.
Ive got a spacer that ill be removing from mine in about a month if thats where your problem lies and your interested?
Paulm280885
So my reader came today not to sure how it works but when I connect it and go into dtc it's says no codes yesterday I cleaned my maf and reset my ecu and the eml went and has not come back yet is this why it says no Codes ?
And Nathan what does the spacer look like ?
ChrisGB
Quote from: "Paulm280885"So my reader came today not to sure how it works but when I connect it and go into dtc it's says no codes yesterday I cleaned my maf and reset my ecu and the eml went and has not come back yet is this why it says no Codes ?
Disconnecting the battery clears the codes. Have a look at pending codes to see if anything is logged there.
Paulm280885
How do I access pending codes mate ?
ChrisGB
Quote from: "Paulm280885"How do I access pending codes mate ?
On the OBD reader software, you often get the option to read logged fault codes and a separate option to read pending codes. Pending codes are codes where there is a logged fault that needs to occur a number of times before am EML comes on.
Paulm280885
Hi Chris
Should the mil light be on or off ? And should the cat be ready or not ready ?
Paulm280885
Lil help please guys
ChrisGB
Quote from: "Paulm280885"Hi Chris
Pending codes are logged faults that may be one off events. An example would be a catalyst below efficiency code. One occurrence would show a pending code, but would not trigger an EML. Maybe after two or three more occurrences, the EML would come on. Similarly, of you have two or three more start and run cycles without recurrence of the fault, it may be removed from the pending codes list.
Not sure what you mean by the second question?
Chris
Paulm280885
When you go into the I/m menu it has various component of car I.e misfire, cat , 02 sensor etc most say ready but the cat and 1 other says not ready what does this mean ? Does the car have to be up temp for cat to be ready ?
Thanks Chris
ChrisGB
Quote from: "Paulm280885"When you go into the I/m menu it has various component of car I.e misfire, cat , 02 sensor etc most say ready but the cat and 1 other says not ready what does this mean ? Does the car have to be up temp for cat to be ready ?
Thanks Chris
Not sure to be honest, I use Torque app and have not noticed that message. I will have a look next time I run the car (which may be some time as I am up to my neck in 7 day work at the moment).
Chris
The obdii sensor list is generic, usually not ready means the system doesn't have that sensor or test. For example some cars have catalyst heating, the test is still there but the mr2 doesn't do it so it comes up either not ready or unsupported depending on the software of the code reader.
FGrob
Morning.   s:D :D s:D    s:bounce: :bounce: s:bounce:    s:wink: :wink: s:wink:
Paulm280885
Hi
Plug the reader in this morning and it's showing a pending code of po136 which is 02 sensor circuit malfunction (bank 1 sensor2) what is that and where is it
Paulm280885
Anyone
ChrisGB
I  think that is the post cat  sensor. A  search of the forum would confirm it.
