10mm penta-socket?
Started by spit, October 30, 2013, 16:21
Kinda MP&T-related.
Has anyone out there got a 10mm socket with five sides, or a 10mm 10-point impact socket for the lending of?
Perhaps one of you guys running on split rims?
I need to dismantle, clean and reassemble a pooped VVTi unit and shove it back into a spare engine.
Thankee.
Never seen a 5 sided socket.  s:shock: :shock: s:shock:
LINKY
That the kinda thing you are after?^^
Nearly Stu. From that kit I need the shape of the socket but the size of the bit!
Quote from: "StuC"Never seen a 5 sided socket.  s:shock: :shock: s:shock:
Me either. Must've looked at VVTi bolts hundreds of times, but it was only when we came to tackle them we realised that something wasn't quite right   s:? :? s:?
10mm 10-sided socket is a little more common. I believe its used on split rims (somehow!). Its only a punt but I guess it would fit a five-sided bolt head. What do you reckon? Clickety
Worth talking to your local snap on rep?  s;-) ;-) s;-)
Always a nice excuse to look around the van!  s8) 8) s8)   s:lol: :lol: s:lol:
scottish_turbo
Some cars have started using 5 sided bolts on the brakes (presumably to stop the home mechanic from having a go). Think they are 14 mm though.
There is a selection on amazon, you might get lucky with a 10mm one.
Sorry can't do linky's but have a look at :
 w www.teng.co.UK/014710360-beta-10mm w
This is tool shack website and they have a 1/2inch drive 10mm penta socket for £8.20
Phone is 0800 161 3031
If you can't locate let me know
Good luck
The part no at the above site is 014710360 and it's £8.82 inc vat.
The site address I gave does not take you straight to the page so use the part no on the site.
As stated by others this is typically for brakes.
Does slow down the less than determined and those who are not on our forum!
That's a similar part to the one I linked to Joe. Ste needs the opposite of that.
cabbydave
Any reason you want to split it Spit? If you want another one I can drop it round for you at weekend
Sorry, it has a 1/2 inch drive pin and a 10mm penta socket so not as useful as it would be with a 1/2 inch socket!
redarrow
390679999294 ebay refrence.
The 5 sidded sockets are
from new brake systems.
There 9.50 each includes post....
The above is a size 10mm
Snapon are now as we talk doing the new
5 sided design , that from the snapon van info today....
Regards john
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
mrzwei
Also, the standard Irwin set has got 10 and 11 mm sockets, don't know if they will work.
Ex.MR2 SMT sadly missed.
Ta for the pointers folks. I'll follow them up. No rush.
