Swapping rear bumper - tips ?
Started by 69fb, January 2, 2014, 18:47
69fb
Wondering if anyone has a guide for doing replacing the rear bumper?
Mine was scratched in a few areas so I picked up another one in the same colour to swap over, I Imagine its a case of removing rear lights to get the bumper off, is this correct?
wotugonado
Hi, use the search facility in the top right hand corner as theres a post on here somewhere with pictures of all the fixing points, i used it when i did mine. Good luck
s12vea
Pretty much yeah. I'm sure there is a how to guide somewhere on the forum
TF204 Blue
Another one won't hurt  .....
AmeR
There is a guide in the How To section -  l viewtopic.php?t=12584 l
69fb
Ah cheers. I did search but obvs didn't enter the correct terms. That will be a great help!
69fb
guide was spot on and easy to follow, managed this in half an hour and also had a chance to inspect the subframe.
Unfortunately I noticed both front side lights are out. Looking at the position of them, is this a headlight out job to replace these bulbs?
