Door warning light
Started by Webby20001, January 13, 2014, 13:20
Webby20001
My door open warning lights keeps flickering on along with the internal light while I'm driving along with the door firmly shut, anyone any ideas what it might be, what I can check?
Mikeymead
Possible chafed wire on the switch earthing out?
Webby20001
Do I have to take the door apart to get to the switch?
Jay67
the switch is in the door jamb, held on with 1 screw, might be sticking or as Mikeymead says wiring fault
If it is that thing sticking or otherwise faulty, can they be swapped from driver to passengers to help eliminate a component at fault?
tricky1138
Quote from: "StuC"If it is that thing sticking or otherwise faulty, can they be swapped from driver to passengers to help eliminate a component at fault?
Stu - are you asking if they are able to be swapped over or asking if the OP could swap them to see if it fixes the problem?
My drivers door switch didn't work so swapped it for passenger one. That worked for me till I could get a new one!
Kinda the same thing tricky. You have proved the point.
I didn't know if the switches were handed to suit the body. I.e. Righthand or lefthand. You have put me straight, which should give a solution for the OP.  :-) :-) :-)
Webby20001
Thanks for the replys guys, took a while to shut the door and get it to go off tonight just so I could lock it!! I'll take a look tomorrow at the switch
tricky1138
Quote from: "Webby20001"Thanks for the replys guys, took a while to shut the door and get it to go off tonight just so I could lock it!! I'll take a look tomorrow at the switch
That does sound like a faulty switch but the opposite to my problem. Mine didn't turn the interior light or door open warning light on! Replaced and all working in my case.
Yours could just be a loose wire behind the switch.
