Changing rad tomorrow advice needed
Started by Pavett1990, February 3, 2014, 19:03
Is that the [strike:lmfw2xgf]court injunction[/strike:lmfw2xgf] incident involving the poodle and the 3/4" impact wrench?
Jay67
Quote from: "StuC"Is that the [strike:6z1ofzp4]court injunction[/strike:6z1ofzp4] incident involving the poodle and the 3/4" impact wrench?
no not THAT incident! It's because of the [strike:6z1ofzp4]community service[/strike:6z1ofzp4] ticking off over the accident with the ferret and the 10mm deep socket
Pavett1990
Re-assembly  s:D :D s:D
nathanMR2
Well youve done the easy bit by the looks of it  s;) ;) s;)
Now bleed it   s:bounce: :bounce: s:bounce:
Quote from: "Pavett1990"Re-assembly  s:D :D s:D
You managed to get that pipe clip back on OK then?   s:wink: :wink: s:wink:
Pavett1990
Quote from: "nathanMR2"Well youve done the easy bit by the looks of it  s;) ;) s;)
I'm waiting on delivery of coolant lol.. That will be laters game haha
Quote from: "StuC"
Yeah took the clips off and started again and just slipped into place.. No need for lube  s;) ;) s;)  lol
 s:lol: :lol: s:lol:    s8) 8) s8)    s:lol: :lol: s:lol:
Pavett1990
It's handy knowing someone in the trade  s;) ;) s;)
£4 for 5 litres of anti freeze
Pavett1990
So far it's taken around 6 litres of coolant.. So by my calculations it's due another 3-4 litres.. But it's getting late to be revving and driving up and down the street so going to have to finish tomorrow
Quote from: "Pavett1990"So far it's taken around 6 litres of coolant.. So by my calculations it's due another 3-4 litres.. But it's getting late to be revving and driving up and down the street so going to have to finish tomorrow
Really surprised that much came out. No idea how you managed that!
Pavett1990
The bottom half of the old rad was non existent most of it was lost through that
Even bigger mystery then is how it stayed in for so long haha
Pavett1990
Lol.. Well my assumption is the stone that hit it finished it off lol
Hull Tiger
Quote from: "Andys-N20"If you are lucky enough to live near a steep hill park with the nose pointing uphill and no need to clamp the pipes swap out the rad, spin the car around and then you can bleed it. That's what I always do.
Bleeding it can be a nightmare sometimes.
Thats easy for you to say, your driveway is perfect   s:) :) s:)  , try living in hull, flat as a pancake   s:( :( s:(    s:( :( s:(
Tomo70
Yeah I nearly burnt my clutch out trying to get off the drive  :-) :-) :-)
redarrow
#40
You need also to run the heater hot to
See if there no air lock.
If there a air lock the heater wont come on
Or get hot.
To get rid of the air lock you undo the radiator cap
And goto the coolent bottle undo that cap and blow
Hard in the coolent bottle untill air bubbles out of
The radiator......(dont drink the coolent use a cloth to
Protect your mouth/face )))))
Worked for me any way....,
Congratulations you saved £££££ from a shop mac
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
Quote from: "redarrow"You need also to run the heater hot to
Or get hot.
Alas there is no radiator cap  s:) :) s:)
Only two little taps on the top left and bottom right and a bleeder valve by the front wall.
Andys-N20
#42
Quote from: "shnazzle"Alas there is no radiator cap  s:) :) s:)
True but the principal still applies.
Park with the rad pointing downhill (lowest point), take the coolant cap off the reservoir and loosen the bleed screw on the top of the rad. The water will naturally flow downhill pushing the air out.
Personally I would not put my mouth anyware near the coolant as I believe the chemicals in coolant can result in blindness and brain damage.
This is an old thread so you must have sorted it out?
Hope so
204.2 BHP Silver 2000 MR2, 2006 2ZZ engine, Apexi PFC, Zorstec full stainless system exhaust (including 400 cell cat & race header), titanium heat wrap, MRW underdrive pulleys, handmade short ram intake, Hondata intake gasket, Celica gearbox ratio's, LSD.
Edge 306 speakers, Alpine CDE 235BT, sound deadened doors.
Full facelift conversion including bracing, sub frame, the works...
