soft top sag
Started by nimrod, March 3, 2014, 08:25
nimrod
My soft top is sagging compared to what it used to, I have used up all of the adjustment, what can I do? a while ago I did come across a thread where the hex nut can be cut down, is that the only solution, touch wood no problems with locking, or water getting into the cabin.
Barney Bear
Have you checked the strap for the ear problem .?
54 Sable, Air con, hardtop
nimrod
Not recently, as my top has been well and truly up, I will check over the weekend, I am assuming that can cause sagging?
