Yellow Stuff pads - anti squeal shims
Started by chimpman, April 11, 2014, 19:39
chimpman
got me some yellow stuff pads prior to my first track day. The OEM pads have two shims per pad, the EBC pads have a single shim per pad. im assuming that you hould just use the single shim supplied with the pads rather than try and reuse the shims from the old pads. Thoughts?
2005 Chilli Red. Mods.... Pine magic tree
MR TWO
How are these pads?  Are they the Eldorado of braking or is it a myth?
SteveJ
Quote from: "MR TWO"How are these pads?  Are they the Eldorado of braking or is it a myth?
They are extremely good for a mix of road and airfield type track day
SteveJ
Quote from: "chimpman"got me some yellow stuff pads prior to my first track day. The OEM pads have two shims per pad, the EBC pads have a single shim per pad. im assuming that you hould just use the single shim supplied with the pads rather than try and reuse the shims from the old pads. Thoughts?
Just use the sticky-back shims that come with the pads.
Fine for circuits too. Great pads.
Use the stick on backings.
chimpman
ta.... im actually taking it to a local garage and just want to make sure. id do it myself but have no garage or drive, my road is narrow so bit wary of getting run over.
