che lotus
Started by peteyb, June 10, 2014, 14:43
shiny
Quote from: "Meeerrrk"Considering half of the price is shipping, what do you expect for £125?!
Considering the engines at the back its only half a system! 70 pounds shipping.
Try telling that to all other manufactures who charge ~£400 for just the back box! Unbelievable!
redcarblackhorse
the che is loud when you rev it but when holding at steady revs it is not that loud at all. I did measure it for Meeerrk and it was 88db at steady RPM.
1999 MR-S with a few tweaks!
Circuit de catalunya
24 Heures du Mans
Thruxton
Abingdon Track day
redcarblackhorse
I also got mine from top speed autos a few years ago. Tell them you're from the club and ask them to do a special invoice for shipping. My invoice was for USD100 so import duty was about £20.
In the end mine was about £200 cheaper than getting a Cobra
24 Heures du Mans
Thruxton
Abingdon Track day
I asked about an invoice for lower uk duty;
They are willing todo it but it carries some risk. If the item gets damaged or lost, the insurance covers the customs value, so if it's only marked as £100, that's all you'd be covered for.
If you look at it like an insurance risk, it's up to you how much you want to cover should the worst happen
Paul1087
Well I ordered one for my 2zz. Should be here in a week or so.
Will post up more when its here.
tomaky
Happydays  s:) :) s:)  thinking this is my fall back tbh.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Escy
Is there much of a weight saving with this system?
I would have thought so...the std rear box is a beast
Escy
Are there any performance gains to be had from it? (mines running a 2zz)
Who knows...the manufacturer / seller claims so. In reality I would think so, over the std box
Paul1087
#36
Will have mine fitted this week on my 2zz, will report back bum dyno numbers shortly!
Much lighter than standard, much freer flowing than standard, much louder than standard, a 2zz should have full reign to screen its song through it.
Performances gains are impossible to estimate, the only way to know is to fit and measure / map according to your setup and other modifications.
But ..... It has to be better than standard   s:wink: :wink: s:wink:
Paul1087
Is there a how to on the fitting for these?
Having an absolute nightmare getting it to
Line up with the cat pipe?
It fouls and i cant see anyway of getting it to all go together?
Help please - pics if u got em!
Paul1087
Finally got it fitted, Although it was not easy. The bumper had to be cut, no way it would have gone on otherwise, the hanging brackets could not have been fabricated correctly and some very persuasive fitting was needed.
Topspeed - good customer service and sent some goodwill my way due to the problems I had fitting.
First impressions - Sounds great, not too loud or boomy. Still quiet when cruising. Bum dyno definitely reporting an improvement performance wise. Nothing earth shattering but it is noticeably quicker when it hits lift.
All in all - recommended. But dont expect it to go on easy!
100% the best looking mr2 exhaust! Good work for sticking with it
tomaky
#41
You sir are wrong! its the postert!
Westfield Seiw
Ex - 2003 Sable
martin_b
#42
HI,
I'm just about to order one of these from Topspeed.
Do you think every installation will need to include cutting the rear bumper, or were you just unlucky?
"Anyone who is not shocked by the quantum theory has not understood it."  Neils Bohr.. Attributed
I'm pretty certain all will need to cut the bumper, I assumed that was common knowledge
Quote from: "tomaky"You sir are wrong! its the postert!
Not a huge fan of the twin exit (1 each side)
tomaky
#45
Sunk into the bumper it looks the business. LUSH
Westfield Seiw
Ex - 2003 Sable
Paul1087
#46
Quote from: "martin_b"HI,
My set up is 2zz, MWR manifold to stock downpipe and Cat, to the Che Lotus Catback.
I think every set up would require some bumper fettling. Which for ease of installation is not ideal - but it does look a lot better and more OEM.
mr-ed_smt
#47
Looks fantastic cut into the bumper - way better like that. Definitely ordering one of these now.
tommyzoom99
#48
yep the bumper will defo need cutting but all worth it in my opinion great exhaust, a few pics of mine taken last year before I came off the road for a complete build
hard to get perfectly in the centre too but after we dropped it on the ground we lined it up ok
cheers tommy
My track project
viewtopic.php?t=51237
andyroo104
#49
Mine was fitted by the previous owner and the bumper was not cut,only the nappy was cut.
