Apexi Power Intake bolt patterns
Started by AndyM, July 7, 2014, 14:28
AndyM
Hi,
This is a long shot... does anyone have/know of anywhere I can find information about the bolt patterns on the different Apexi filters?
I'm trying to match one to a MAF housing I have but Apexi make tons of different variants and the people I've spoken to so far have been fairly unhelpful in trying to pin down the one I need (Nengun have been specifically annoying as they basically said they could tell me the answer but they won't in case it doesn't fit and they are then liable for a refund   s:evil: :evil: s:evil:  ).
Also, if anyone happens to have an Apexi lying about... I'm looking for one with a rectangular 92mm x 51mm pattern with the internal diameter of the 70-75mm if you don't mind grabbing a tape measure.
Thanks,
Andy
EDIT: Taken a bad reference to Apexi USA out as they turned out to be great.
AndyM
Solved!
I take it back about Apexi USA, their tech department have been very helpful and specifically opened up a filter to measure for me.
The answer by the way for the dimensions above is part #500-A022
Glad to see the maf housing is going to be of some use.
AndyM
It will mate. Getting it powder coated if I can find a reasonable quote and all the fitting bits are in the post as we speak.
