7J ET35 Rim - wheel nuts
Started by Paul1087, July 15, 2014, 13:52
Paul1087
to fit with Pro Race 1.2 's
Can someone advise on what new nuts are needed.
Length and seating face style please
  s:D :D s:D
Goeman
M12 x 1.5mm with a standard 60deg cone seat. Any length should fit.
Russell
Paul1087
Thanks Russell - what are the stock nuts out of interest? Just want to check I definitely cant use them before I order some new ones.
Goeman
You can't use the stock nuts. They have a 90deg shoulder and half the nuts sits inside the wheel's bolt holes. I think they're Toyota specific.
Russell
Paul1087
 m http://www.performancealloys.com/nut-de ... spx?ID=162 m
These should do nicely then right?
Goeman
Yep. The stock wheel studs aren't that long so nut depth/hight should be fine.
Russell
