oxygen sensor/ lambda sensor
Started by zxr400, July 30, 2014, 10:13
zxr400
My lambda sensor has failed. I have tried cleaning it but it still showing as faulty on the dash. Has anyone tried Haas lambda sensors
as they are only £45 at Europarts and in the photo they show a connector so I wont have to cut any wires. They said it has 1 years warranty
as well.
Which one has gone? there are 3 on UK cars and 2 on jap imports?
Best place to get them from is sparkplugs.co.uk as you can get the proper Denso ones. I'll point you in the right direction when you let me know which one you need. BTW, what was the error code you got in the diagnosis?
zxr400
My mr2 is a uk version. The error code is PO155 which I believe is the front left sensor with the short lead.Thanks for the help
Sparkplugs.co.uk ref DOX 0204
linky
zxr400
Just looked at site is it okay to use denso universal sensor and cut my own wire or would you not advice this
Denso is the OE for the MR2. The sensor is universal, it's the lead length that changes.
The sensor will come with a fly lead to match the engine installation. No cutting will be required.
What StuC said.
Pay the extra 20 quid and get the proper OEM one. You will more than save the 20 quid in time not messing about cutting, splicing and joining.
Unclip-unscrew old one. Screw in and reclip new one job done.
normanh
You cant fault the service from Sparkplugs Co Uk, changed mine a few months back on a PO155.
Norman
shiny
Quote from: "zxr400"My lambda sensor has failed. I have tried cleaning it but it still showing as faulty on the dash. Has anyone tried Haas lambda sensors
as well.
Just changed one of mine with a Hass from Eurocarparts nothing wrong here.  s:D :D s:D
zxr400
How long have you had the haas sensor fitted for and does it  come with the connector or do you have to cut the wires
shiny
Quote from: "zxr400"How long have you had the haas sensor fitted for and does it  come with the connector or do you have to cut the wires
Done around 100 miles so far no problems and yes comes with the connector.
stupink
ECP cheapies worked well on my turbo for at least 400miles before i cut it off for essentially no apparent reason... (long story)
