Head Lights Polished - Meguires
Started by gaffer1986, August 23, 2014, 18:56
gaffer1986
Did this today, quite please but I thought it seems others on here have had better results:
Before:
After:
gaffer1986
Must say, it looks better in the photos.
tomaky
Its an improvement but you cant beat the machine polish. If we ever cross paths id gladly whap the polisher on  s:) :) s:)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
gaffer1986
That's very kind of you  s:) :) s:)  It's a shame I can't find any aftermarket headlights, I think it would good with the internals black like the below link:
http://www.norcalmr2.com/mrs-headlightinstall/
gaffer1986
Does it help if you polish the inside of the lenses also?
trickyD
I use Farecla G3 paste and waffle pad which works well also, but only lasts 2-3 months until the sun degrades the untreated plastic.
Does anyone know how to stop the UV damage?
And don't say Sunscreen!
Bits for sale!
Strangely you have answered your own question
You do use sunscreen - for plastics.
Aerospace 303 for instance. UV protection for your stuff. (spf 40)
edit
http://www.autogeek.net/303aerprot.html
tomaky
Gaffer if your splitting the lenses to polish the insides you might as well paint the internals black  s;) ;) s;)  its been done before  s:) :) s:)
Westfield Seiw
Ex - 2003 Sable
trickyD
Thanks Ardent  s:) :) s:)
I did wonder if it would work
Bits for sale!
ashtons99
I did mine this week with Meguiars cutting polish on a microfibre pad on DA. They have come up great, taken all stone chips out too.
tomaky
Be warned splitting them is a paint in the backside.
Westfield Seiw
Ex - 2003 Sable
nimrod
I thought about splitting the headlights, as mine are going slightly inside, but chickened out, I was also worried when fitting back together that they might not be as air tight.
tomaky
Air tight isnt so hard, think its more splitting the swines.
Westfield Seiw
Ex - 2003 Sable
My pfl headlights aren't air tight they have sponge filled breather holes as OE.
no1trancefan
Quote from: "gaffer1986"Did this today, quite please but I thought it seems others on here have had better results:
Before:
After:
these are the spitting image of min,e on my to do list, anyone got a guide for getting the headlights out will be my first attempt
tomaky
Machine polish...
Westfield Seiw
Ex - 2003 Sable
gaffer1986
I probably won't bother splitting them, I know someone who has done a few with a machine polish and wet sand paper, may get him to give it a go. BTW I did 6 goes of the polish on each light to get this result.
trickyD
What grade sandpaper? Seems a bit excessive.... :/
Bits for sale!
mikews
Start low - 800 and work up...
I have a headlight that's no use, May split it later and then do a test, sandpaper part, machine another, hand polish, toothpaste, any others ?
trickyD
Please do!  s:) :) s:)
Bits for sale!
mikews
So, as I said I had an old headlight with broken clips so thought i'd split it and give the lens a few polishes using different products
Some pics of the headlight before
Once the missus had gone to bed (she works nights), I chucked it in the oven. Remember to remove all bulbs, rubber caps and the screw at the top of the lens on the back. Fan over at 140 degrees for 10 minutes. Split amazingly easily however the sealant went everywhere. I'd recommend you have a second pair of hands to aid with stopping the sealant ending up on the interior plastics.
Once it was separated I segmented the lens up into 9 sections using tape.
Section 1 was sanded with 400, 800, 1200, 1500 & 2500 dry followed by 2500 wet. (Few £ in halfords for a kit)
Section 2 was sanded at 2500 dry then 2500 wet only.
Section 3 - Aquafresh toothpaste. (£1)
Section 4 - Meguiars Ultimate Liquid compound (~£10 @ halfords)
Section 5 - Car pride scratch remover (£2)
Section 6 - Astonish Oven cleaner(£1)
Section 7 - Mantis Scratch Remover (~£12)
Section 8 - Wilko own brand colour restorer (£2)
Section 9 - Autoglym Paint Renovator(£8)
At this point all products were applied by hand
The ones I felt were best were
It's worth mentioning that the tape used to separate the sections had been removed at that point showing the original state of the lens
And a quick overview. The 3 you can make out are the 2 just sanded areas and Astonish oven cleaner (proves to be no good on headlights but great for exhausts)
My personal opinion was that the Autoglym Paint Renovator had done the best job and been the easiest to use, so I gave the whole lens a buff by hand.
This brought out most of the marks and the whole lens is looking better generally than before. I grabbed the rotary out and decided that I'd try using the AG on a waffle pad, which was working however have had to pause proceedings as the mop is just far too loud whilst the OH is sleeping.
One thing I did notice though is that the AG is far too "wet" and was getting flung everywhere. Will update later once I have a chance to attack it.
trickyD
What a guy!!! Thanks  s:) :) s:)
This should be a sticky
Bits for sale!
mikews
Right its finished
Found that with the Autoglym Paint Renovator when used on a rotary, you only need a tiny amount applied frequently.
Ended up with great results - Straight after being hit
Then I gave it 2 coats of Meguiars Carnaubu Wax
So from my, not so scientific, test, a good finish can be achieved by hand using off the shelf products, however really a machine polish is the only way to perfect it.
Fin
That looks fantastic!! I have a spare set in the shed that need work. When you say 'Autoglym paint restorer', do you mean their paint 'renovator'?
I just want to make sure I get the right product   s:wink: :wink: s:wink:
I have got the fleece pads etc, would I get a better result using sponges (mops)?
Extremely chuffed you were willing to take the time to do this and post it up! Thanks   s:bowdown: :bowdown: s:bowdown:
The roof is down on my MR2,
Superb!
A sticky in the making as suggested.
