Window ajustment(air gap).
Started by stupink, November 23, 2014, 11:13
stupink
Got an air gap at the very bottom of the window against the window seal,  My last pillar-less car had ajustment along the inside of the door to change position and angle of the window.. is the 2 the same? currently a bit poorlies so not able to go outside to investigate so doing a bit of research first  s:) :) s:)
Yes there is adjustment you have to take the door card off. I found the information either on here or spyderchat years and years ago, but effectively you can adjust the angle of the glass
stupink
Cheers.. i had a look earlier in the end on the door ends and there was nothing. so looks like i need to get the cards off.. gives me a chance to dynomat *cough flashing tape from b+q* the doors..
