P.E TURBO OWNERS what psi?
Started by maybeturbo, February 14, 2015, 23:29
maybeturbo
Just curious as to what psi any other PE turbo owners run? And what boost control are you using?
Mine sits at a pretty solid 5 psi,  controlled by a bleed valve. I've bought an apexi avcr but not fitted it yet as had no time of late. Be interested to hear what you guys are doing?
I would be careful on turning it up, lots of other bit also need to be adjusted depending on your current set up.
maybeturbo
Of course.  I'm more interested in the capabilites of the turbo.
I used to run that kit at around 7.5 psi, with appropriate map , when I had it.
