Air/fuel ratio
Started by lamcote, February 25, 2015, 00:20
lamcote
I'm just getting my head round fuel trims and open/closed loops etc, all very exciting!
I wonder if anyone can tell me what air/fuel ratio the standard map gives at maximum load? I have seen reference on other forums to standard maps going as rich as 11:1 (Lexus I think) and I wondered what ours is.
Secondly, does anyone know how much difference a piggyback map such as emanage makes to the standard air/fuel ratio settings on a naturally aspirated engine?
At the moment I am guessing that a custom map gains more from changes to the ignition map than the fuel map but I am happy to be told otherwise.
Another assumption I have arrived at is that the long term fuel trim is used to adjust the mixture settings in both the closed and open loop, is this correct?
Glubux
As far as I remember, Afr at maximum load on my stock engine was around 13.5 from 1000 to 3500 rpm and then 14.7 till 7000rpm.
