3 amigos stud but size?
Started by grant82, April 15, 2015, 13:20
grant82
My local Toyota dealer has said that they don't have the nuts in stock and won't have then for 5 days. I want to get my manifold back on and this is all I need. Can anyone give me the size and type please. Thanks
dan944
I struggled hugely trying to get these sizes and with no avail. An option(I'm gonna get torn apart for this) that I used I so put narrower bolts through the holes with nuts to hold them tight. I ran about 3-4000 miles like this and weirdly it didn't bless at all. And if you can't get them off after wards ou can just cut them off as they will just pull straight out once an end is removed. It's not ideal but it's an option.
Honda CR-V The Work Horse
tricky1138
Grant,
I think I've got a set somewhere. I'll check at home tonight and let you know if I do.
Tricky.
grant82
Awesome
GSP (affiliate on ROC) have them listed here.
Incidentally I have 2 spare ones in the glovebox if tricky can't find his. How many do you need?
grant82
I have the studs it's the nuts I'm struggling with. Was hoping to get the size (pitch/type) so I can go and pick one up...I need all three.
Fin
(Preparing to be shot down in flames).
I can't remember the pitch/size, but I had similar problems when I replaced my manifold (the box had got wet in one corner, so I assume that's why I didn't get the studs with it).
As a result, I bought a pack of 10 bolts of the correct pitch/size. I have 7 left in my bag o' bits if you need some?
The roof is down on my MR2,
grant82
Certainly, but as tricky has offered above and is local to me I will hang on for them. Failing that I will take 3.
krazysteve
i think they are M10 x 1.5mm, if not M12x 1.175mm, pretty sure i had 2 shear when i did the precats and re- tapped to M12.
RACING, because football, cricket, rugby and golf only need ONE BALL
tricky1138
Sorry for the delay, been out meeting new members!   s:D :D s:D
I've had a good look for them but can't find them!    s:( :( s:(
But I have just read the rest of the thread and if you only need the nuts then I'm sure I've still got the old ones.
The problem with that is they're in the same box as the head nuts, does anyone know the difference, if there is one, between the head nuts and the 3 amigos nuts?
Fin
No worries. If everything else falls through, just PM me  s:D :D s:D
