Obd2 readers not working!
Started by shnazzle, May 30, 2015, 16:50
Does anybody have either one of these two eBay obd2 readers?
Both of them work in our other car, but not the MR2.
Stewart@Boro has used his on my mr2 and it does work. So... It's not the port, it's not the readers it seems because they work in the Audi... What gives!?!
I've spent a whopping 8 quid in total for these two
Mr X
maybe app settings not scanning for the protocol? or the 8 quid in total?  s;) ;) s;)
I have one that looks identical to the right hand one. Except for the writing. Was an Amazon purchase. £6.
Works fine.
I assume your using the fully paid up version of Torque?
If not give it a try.
Using paid version of Dashcommand, as I have for years.
As I said, it works on the audi... Very odd
Mr X
get torque lite (it's free) and see if that can connect.
Quote from: "Mr X"get torque lite (it's free) and see if that can connect.
Good thinking batman.
I shall try
Quote from: "shnazzle"
I shall try
Do or do not. There is no try.
I have done. No dice. Plugged it into the audi, instant connection. Literally the second I plugged it in.
tricky1138
Right hand one looks very similar to mine. Works fine on the Mr2 but doesn't work on the Land Rover!   s:scared: :scared: s:scared:
What reader has stew got?
He's got a fancy pants 100 quid BlueDriver or something like that
mikews
I've got the right hand one and works in mine with torque
stewart@boro
100 dollars please  s:wink: :wink: s:wink:
It does do a lot more than read the codes and it's the only one I have tried which works with an iPhone and an iPad.
TF 160 TTE exhaust and style bar and other shiny bits.
Replaced by an Abarth 124 Spider
Quote from: "shnazzle"He's got a fancy pants 100 quid BlueDriver or something like that
Flash Wan*er!
Mine works fine in my mr2, fine in the Nissan, but tried it in a friends focus and didn't work; and my old vectra wouldn't work with it either.
So I feel your pain, I know obd2 is supposed to be a single standard but it doesn't seem that straightforward
Does it have any leds? If so do they light up ? Once mine was pushing the connector back and not quite connecting, but another connector which was slightly thinner plastic was ok.
It does indeed have Leds. Can just make out the power one. The other two are dead. Funny thing is that it did work once with  the old one (right one). Just once and never again
Got the one on the right and it didn't work, I paired it and got it to connect but it set my ABS flashing and lit up the airbag warning light (see vid) I contacted the seller and he sent me another one foc and it does the same.......... [youtube:2izxvka2]H4krMOXU948[/youtube:2izxvka2] if you plug it in after starting the engine the ABS doesnt flash but the airbag light is showing dim all the time.
You pays your money, you takes your chance.......... it cost less than a fiver
Mr X
are the pins ok on the obd2 socket? first thing it should do is start flashing the bluetooth one. If the light is dim maybe it's not got the correct voltage/earth?
 you get the abs thing because these are generic (mine cheap one did this that i've now replaced) and it trys to talk down the lines toyota use to communicate with the abs ecu. I made a post about pulling the abs pins to fix that.
If I leave mine in and switch on the ignition, the abs flashes.mi think Scott's does the same, he pointed it out to me  s:) :) s:)
Airbag flashing thing  is a well known prob. Something to do with the pins and how it scans for an obd2 connection.
But NO connection is crap.
What still puzzles me is why it works perfectly in the Audi
stewart@boro
The cheap one I bought first from eBay set off the abs just the same  s:( :( s:(
stewart@boro
Quote from: "1979scotte"
Flash Public sector pensioner with a nice redundancy payment  s8) 8) s8)
Fixed that for you  s:D :D s:D
Quote from: "shnazzle"Airbag flashing thing  is a well known probably. Something to do with the pins and how it scans for an obd2 connection.
I don't get that either, I've had the same problem though! Ironically the mr2 has always worked though
