meister r coilovers
Started by wotugonado, July 3, 2015, 19:35
wotugonado
Ive just bought some meister r coilovers, whilst greasing them up prior to fitting ive moved the spring pre tension collars.
Does any body know what setting they should be set at ?
And what difference does this make to set up ?
I think I remember the BC coilover manual saying that there shouldn't be any preload. So I guess just put the collars up against the springs tight but not so much that the springs compress?
wotugonado
Cheers snazza   s:) :) s:)
Had a quick look at meister r manual (leaflet) and that says 2mm of pre load   s:? :? s:?
What difference does it make to the handling ?
Cool. I guess 2mm is pretty much just a slight tighten against the collar. Good stuff!
wotugonado
 m http://www.civiclife.net/board/topic/86 ... coilovers/ m
just found this thread on another forum but thought id post it as its a good reference for anybody with the same query as mine
Quote from: "wotugonado"http://www.civiclife.net/board/topic/86558-how-tight-should-you-make-the-springs-on-meister-r-coilovers/
just found this thread on another forum but thought id post it as its a good reference for anybody with the same querie as mine
Handy.
Might try sometime
