2001 Mk3 A/con filter
Started by Roymundo, July 15, 2015, 19:39
Roymundo
Did Toyota install a filter/pollen filter to the air con system on a 2001 mk3 MR2, if so can someone assist and inform its location. I've had a look inside the cabin around the steering wheel but nothing. With it been a convertible can't see why one would be fitted, but you never know. Thanks....Roy
Lurch
Not sure Roy as mine doesn't have AC but on my other Toyotas it's located behind the glove box, passenger side. Drop lid down and pinch sides in, it should drop leaving the filter exposed behind in a slot.
LURCH
Roymundo
Thanks Lurch, glove box removed however filter not exposed. Some plastic Denso containers but they appear to be a permanent fixture. Unless anyone knows different. Cheers
Lurch
Looked at a previous post, seems there is no filter fitted for the roadster.  l viewtopic.php?f=11&t=30316&hilit=40k+service l  Hope some help Roy.
LURCH
Roymundo
Cheers for the information, I will stop looking for one.
