Which Magnaflow 200 cell to weld in to decat pipe?
Started by js1mr2, September 13, 2015, 23:23
js1mr2
I'm thinking of getting a Magnaflow 200 cell sports cat to have welded in to my topspeed decat pipe. Firstly do the Magnaflows sports cats work well enough to pass an MOT, I'm a bit suspicious of the sub £100 price? Secondly what is the correct size? Cheers Jeremy
js1mr2
This is the sports cat I'm considering:
http://www.ebay.co.uk/itm/2-25-57mm-Magnaflow-Universal-High-Flow-Sports-Catalytic-200-Cell-Cat-59955-/261577688434?hash=item3ce73ec572
just not sure whether to go for the 57mm pipe size and try to have it fit inside the decat pipe, or the 63mm and try to have it fit around the pipe.
https://www.dropbox.com/s/8ptwg5tpuy4d4ay/IMG_4740.JPG?dl=0
Any ideas?
Mark A
The size indicated is usually to fit over the diameter tube, 2.5 inch will be slightly larger than 2.5 inch, I used the same cat and supplier, had it welded in and passed the mot.
js1mr2
Ok thanks that's reassuring. Did you have it welded in to a decat pipe you bought separately or have it welded in to a stock mid pipe? Can you remember which size you went for?
Mark A
I butchered a CHE CAT/mid pipe with a damaged CAT. The stainless steel was so poor I had real trouble welding and to took to someone who shouted and swore because the quality of the metal was dog *hit
js1mr2
That doesn't sound good, not sure if mine is a CHE or topspeed but probably equally as bad. Can you remember whether you went for the 57mm or the 63mm sports cat?
js1mr2
Anyone know what size magnaflow sports cat fits a topspeed decat pipe, 57mm or 63mm?
Mark A
Measure the pipe diameter?
js1mr2
It looks like 60mm to me so not sure whether to get cat that is larger diameter or smaller
I would think larger based on no real knowledge what so ever.
Mark A
Looks 63mm or 2.5 inches and available on auction site item number 251630550977. This is the same as the one I used and passed mot no problems.
Mark
js1mr2
Ok thanks, I'll probably go for that one and have it welded in to the decat.
Mark A
You don't need to weld it into the decay, simple cut the old one off and weld in the new one
