2zz vs 1zz 95 octane fuel
Started by wilko59, September 26, 2015, 09:52
Yes the 2zz flows huge amounts of air when in lift so HAS to have a good manifold and exhaust system. It really does choke the car up I'm afraid
Lee H
Very disappointed, was expecting something similar to our EP3 and it didn't deliver. Started trying to sell it two weeks after the swap.
I'd guesstimate it's making about 170bhp max. Was making 160bhp on the 1ZZ when I originally got the car.
2000 black Roadster - hardtop, 16" Rota Grids with T1R\'s, TTE springs, TRD bodykit, JDL spoiler, 2.0 16v turbo swap with forged internals, Apexi AVCR, Apexi intake, ST205 chargecooler, JP custom exhaust, Accord Type R Recaro\'s
mattbrown82
I changed from a stock cat and exhaust to a custom system on my 2zz and it feels alot better in the higher revs. The 2zz can't compete with the k20, but if we get the dyno day done we'll hopefully be able to see how restrictive the cheaper manifolds are.
All depends on how many variations we can get on the day...
[size=85]00 silver
01 Blue 2zz - sold
03 Sable - sold[/size]
mattbrown82
Might be worth bringing a stock 1zz as well as a baseline.
[size=85]00 silver
01 Blue 2zz - sold
jonty
back to basics on this car - have the lift bolts been checked?!
Lee H
Quote from: "jonty"back to basics on this car - have the lift bolts been checked?!
Fitted new ones when I built it.
jonty
OK mate, thought it was worth checking! Must be the exhaust as the only thing that is different to us guys who are happy with the performance.
t'll be interesting to see if the exhaust does get changed whether the rolling comparison works our differently, but best proof is in the whp off a rolling road. Early next year should be fun, I'll be part way through 6 months of paternity leave and probably needing a break from nappies and dodgy sleep patterns!
wilko59
Well the celiac manifold is on its way, don't know if the jag can is staying or to be swapped with a powerflow.  Looking at having a rolling road done on both cars, somewhere in Sheffield for £25 so I'm told.  Will keep you posted.
Red Edition -  Widermuller\'s bling, short shifter, ultimate gear linkages and billet cage mounts.  Garage59 manifold, Proflow quad exhaust and sports cat.  Kenwood/Garmin DNX.
Previous - PFL Blue H/Top & MRs Black 2zz
Who's going to weld the celica manifold up?
mattbrown82
£25! That's cheap. Cheapest I could find locally was £65.
[size=85]00 silver
01 Blue 2zz - sold
wilko59
Quote from: "Meeerrrk"Who's going to weld the celica manifold up?
mr2will is a dab hand with a welder.
jonty
#36
Please get a before and after dyno of the 2zz, it would be really interesting to see!!
Quote from: "wilko59"
Nice! Can't wait to see the results
Quote from: "jonty"Please get a before and after dyno of the 2zz, it would be really interesting to see!!
Absolutely, this would be the slam dunk we are all waiting to see - does the eBay manifold lose that much power from stock
Paul1087
Yep, that would be really helpful .
I have a celica manifold here ready for chopping and welding. Would be great to see some figures before going ahead with it.
Does anyone know how the Corolla and lotus exhaust manifolds differ from the celica and if anyone has considered those as an alternative?
wilko59
#41
2zz booked in for half one today, will be a couple of weeks before the new manifold is fitted due to working away. But I'll keep you all updated.
Paul1087
#42
Quote from: "Meeerrrk"Does anyone know how the Corolla and lotus exhaust manifolds differ from the celica and if anyone has considered those as an alternative?
Pretty sure they are all the same, although not 100%.
this link shows the variations of 2zz manifold - no differences between models noted.
 m http://www.ddperformanceresearch.com/ad ... _guide.pdf m
Quote from: "Paul1087"
That's interesting, thanks.
I'm tempted to try it, to compare to my exhaust
jonty
#44
Quote from: "wilko59"Dump booked in for half one today, will be a couple of weeks before the new manifold is fitted due to working away. But I'll keep you all updated.
Cool, looking forwards to seeing the results!
wilko59
#45
Ok, three runs this dinner time at Autotronix in Laughton S25 (says he can do a group of ten at £25 each by the way)- 165, 165, 166 bhp.  Was told it was running a little bit rich which if corrected would see a slight increase to perhaps 170, but not going to look into this until the new exhaust setup is done.  I was told most jap cars have a tendency to run slightly richer as a failsafe.  Peak power was at 7281rpm.  Incidentally peak torque was was around 6800rpm.
Will probably be a week or two due to work then we'll have it tested again along with my 1zz.
Jrichards20
#46
Ok, so corrected fuel ratio and your missing 20bhp. restriction my well do 10-15bhp. which is about 180bhp-190bhp. Which if im not mistaken is the normal power for a 2zz?
Street Triple 765 RS
Correct Josh !
Quote from: "wilko59"Ok, three runs this dinner time at Autotronix in Laughton S25 (says he can do a group of ten at £25 each by the way)- 165, 165, 166 bhp.  Was told it was running a little bit rich which if corrected would see a slight increase to perhaps 170, but not going to look into this until the new exhaust setup is done.  I was told most jap cars have a tendency to run slightly richer as a failsafe.  Peak power was at 7281rpm.  Incidentally peak torque was was around 6800rpm.
That's actually very interesting thanks for posting. So Lee guessed it was making around 160bhp he was pretty much spot on!!
It's interesting your car makes its peak power at 7200, I don't know any facts but I would expect it to be higher, more toward 8000rpm which suggests it could be an airflow restriction because we are all told these engines flow insane amounts of air at high revs.
Can't wait to see the difference with a celica manifold!
Top work
Paul1087
#49
Can you please post your dyno print out?
