I've created a monster truck! And some other problems.
Started by Jrichards20, October 30, 2015, 16:15
Jrichards20
Problem no1. I've managed to transform my 2 into a monster truck.
Problem no2. Wheels are slighter bigger than I imagined!!!
Side view.
Problem no3.
When I drive, over 15mph and under braking. There is a loud humming noise. It is not a good noise. But haven't a clue what it could be?
By just changing the wheels over I've created three problems.
Massive ride height increase
Width increase so it looks rediculous
Bad humming noise.
Help appreciated  s:) :) s:)
Street Triple 765 RS
tomaky
Fml you need offset!
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
tomaky
What sizes are the tyres and the offset on the rims?
Westfield Seiw
Ex - 2003 Sable
Jrichards20
Front ------------------------- Rear
16x7 ------- Size --------- 17x8
ET30 ------- Offset --------- ET20
4x100 ------- PCD --------- 4x100
56.6 -------- Center Bore --------- 56.6
8 kg ---------- Weight --------- 9.9 kg
195/50R16 ---------- Tyre size ---------- 225/45R17
J03
Yowza!   s:lol: :lol: s:lol:  Arch extension time... go fetch the grinder.
tomaky
Tyre size is spot on. The offset is about 20/25mm out in the rear in my opinion.
Westfield Seiw
Ex - 2003 Sable
scottish_turbo
That width of wheel and offset has been fitted before but ive only ever seen it with a pulled arch and a stretched tyre which wasn't ideal for the width of rim.
Jock
Looks like the wheels came off a Hummer   s:bounce: :bounce: s:bounce: .  Maybe a re - tune   s:oops: :oops: s:oops:  ?
Not sure I agree with Tom on the tyres.
I am running 215-40-17 and according by to my quick search Josh has +40mm on the OD of the tyre. Which would make up some of the tractor stance seen.
Jrichards20
Quote from: "J03"Yowza!   s:lol: :lol: s:lol:  Arch extension time... go fetch the grinder.
Never done anything like that before. How am I going to fix this haha?
Jrichards20
Or does it just look too rediculous that no amount of arch rolling, or lowering the car will help it?
wotugonado
wow!!! quite unique that.
Are you fitting a body kit ?
Quote from: "Jrichards20"Or does it just look too rediculous that no amount of arch rolling, or lowering the car will help it?
Ding ding ding ding ding ding WE HAAAAVE A WINNER!
hamspeed
This was my first thought! Out of interest, how much abuse have the tyres had? Have you had them balanced recently?
02' Toyota MR2 Roadster Race Car -
Owner @ GarageFiftyNine - Supplier of Automotive parts and accessories | Stainless Steel Manifolds | LED/DRL Fo
Jrichards20
Quote from: "wotugonado"wow!!! quite unique that.
Errrr, not sure. Have a jdl bodykit. But unsure whether I will be fitting it or not.
Quote from: "shnazzle"
Hahaha ok I think you have made the decision
Quote from: "hamspeed"
Ok, definitely made the decision then! I've taken the hint guys haha  s;) ;) s;)  I will put them up for sale  s:) :) s:)
Not that much abuse, maybe a millimetre has been used, still got a lot of life in them for r888s. And balanced maybe a year ago.
4dvti
LOL Wouldn't look bad if they were 15" wheels I think   s:D :D s:D
190whp/143wtq & 12.7s 1/4 mile- naturally aspirated on r888s.
Surely you have posted this in the wrong thread, didnt you want to submit that first picture for the 2016 calendar?
Quote from: "Topdownman"Surely you have posted this in the wrong thread, didnt you want to submit that first picture for the 2016 calendar?
Nah, should be in April with the rest of the fools!  s;-) ;-) s;-)
tomaky
Quote from: "StuC"Not sure I agree with Tom on the tyres.
These will be used on track stu so you want abit more in the sidewall with track tyres. What he needs is more offset and lowered. For track wheels i would prefer 16S to 17 thats 1 negative.
Westfield Seiw
Ex - 2003 Sable
tomaky
My 17s are 245-35-17 so not too far away.
Westfield Seiw
Ex - 2003 Sable
Bolt on over arches do the job. Hopefully mine will be a little bit wider than that this year if I ever get round to actually working on my car
wotugonado
probably right decision, without a body kit to hide em, they didnt suit imo
Let's get this straight, you are adding weight to a track car to cover the wheels?
Sounds a little counter intuitive.
Quote from: "StuC"Let's get this straight, you are adding weight to a track car to cover the wheels?
if that's towards me stu then I can say fibre panels weigh less, that and its not a track car   s:mrgreen: :mrgreen: s:mrgreen:
