TD04 Turbo
Started by Mark A, January 27, 2016, 18:58
Mark A
Anybody know which version of the TD04 turbo would suit a stock MR2? Not looking for silly boost just want quick spool up with nice linear delivery up to the rev limit.
I already have a T25 turbo manifold and the TD04s are common, pretty robust plus I've rebuilt them in the past.
I like the look of the Kinugawa Universal Turbocharger TD04L-19T 6cm T25 Flange kit which comes with all the pipes etc, but I cant decide on the 16T or 19T and if a billet wheel is worth the extra £.
Comments or thoughts would be greatly received.
Mark
Who is it on here. Who is running a Subaru td04? Cabbydave?
cabbydave
Not me The deal fell through
Loadsawine? Rbuckingham?
Now I'm just rattling off names... Haha
stupink
if you want good spool why consider the larger exhaust housing?   I've not run td04's that said, I had a td05hr 16g on a 2.0l engine and that spooled so nice but that was because of twin scroll... to be fair these engines don't really make any power low down, so boost or not its not gonna pull until higher rpm, so I wouldn't obsess over spool personally.. opinions may vary  s;) ;) s;)
Not me, think it's blubux or something
Not me, probably one of the few I haven't run! Never say never though.  s;) ;) s;)  I reckon there must be sensible cheap turbos we could use though.  I see some Saabs and scoobys used a td04. Could be interesting.
Mark A
"if you want good spool why consider the larger exhaust housing" Only because i'd read on Saab and Subaru forums that the 5cm housing caused the turbo to run hot with high exhaust temps so recommended 6cm. Thanks for the input.
Ah. That answers the question... Saab was the hint. I believe Scotte's is a td04 the no?
Quote from: "shnazzle"Ah. That answers the question... Saab was the hint. I believe Scotte's is a td04 the no?
Isva Saab turbo but is actually a gt25
I give up
Quote from: "shnazzle"I give up
But you were so close
 l viewtopic.php?f=88&t=57516 l
Argh. Thanks.
well there's something that might help you Mark A  s:) :) s:)  After much ado
keljon
if you have a t25 manifold already then go for a t28 turbo from a nissan s14 or s15 (the s15 is ball bearing so harder to find and more expensive)
Glubux
I tried a TD 035 from a Forester first but it was too small, the boost was decreasing a bit past  6000 RPM
Now I'm running a Subaru Impreza 2000 TD 04 at 7 PSI and I think it is great, it spools nearly as fast as the TD035, it start building boost at 1100 RPM, and hit full boost at 2200 RPM till the red line, almost no lag.
Mark A
Do you know which TD04? Is it a TD04L 13T? I'm thinking of going with a TD04L-16T slightly larger compression wheel 43.5/56mm vs (13T) 40/56mm
Glubux
Quote from: "Mark A"Do you know which TD04? Is it a TD04L 13T? I'm thinking of going with a TD04L-16T slightly larger compression wheel 43.5/56mm vs (13T) 40/56mm
Sorry I don't know for sure, but I think it is hte 13T
keljon
The Impreza td04 is a good choice for a low power setup but it won't be t25 flanged
Mark A
Yep I appreciate that but TD04s can be bought new in T25 format or converted using one of these  m http://www.ebay.co.uk/itm/MAZDA-FORD-FO ... Swu4BVsZeH m
Leethesparky
Mines got a td04 but it's got a larger exhaust housing with a t25 flange. Spools up really quick, but I think it's on its limit now.
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
Mark A
Is it T13 or other
Leethesparky
My engines built around the whifbitz basic turbo kit, have a look at their website because to be honest I've no idea   s:D :D s:D
Mark A
So the Turbo is ordered, went for a TD04 16T. What size chargecooler do people use? 6, 8 or 10 inches?
I got a pwr 4x6 spare
mr-ed_smt
Did you go for a Kinugawa, Mark? I've got my eye on one - what made you go for a 16T over a 13T, or going up to a 19T?
