2zz engine removal
Started by secla, April 7, 2016, 16:22
secla
Plan on removing the engine from my celica donor this weekend.
Apart from the obvious engine/gearbox/shafts/Ecu is there anything else I will need off for the swap before its scrapped ?
beavisrules
some reckon the seats are better.
secla
I just mean what parts solely for the engine conversion !
Exhaust manifold? Unless you're going aftermarket.
Maf housing?
JoeCool
Keep your keys, and the transponder pick up ring around the ignition barell.
Make sure you pull the whole engine loom, you can save a packet re-pinning the ecu plugs and reusing the lift wires.
2ZZ '02 Roadster
