Steering Wheel Boss
Started by Alex Knight, April 26, 2016, 17:07
Hi all,
Had a quick search, but didn't turn up anything deinitive.
Who has a steering wheel boss which self-cancels the indicators?
I'm looking at getting a Personal Neo-Grinta wheel, and would like to mate it to a boss that works!
Many thanks.
TiM3
I have a Momo one that self cancels, got it from Demon Tweeks Direct on EBay
2001 MR2 Roadster - Cusco front strut brace, Chico Racing shift bushes, soft top delete, 2ZZ-GE, Eliseparts sump, 6 speed box, 4.529 final drive, LSD, custom induction, Zorstec 4-1 manifold, 100cel cat, P&P full cage, RRS 6 points, Cobra Imolas, BC Coilovers (5/7) BattleVersion rear arms, polybushed front arms, poly windows, gutted doors and dash.
Thanks chap.
Do you have a link or a part number?
MilesH
Alex, I tried a number of bosses, including two off ebay and the momo mentioned above.
The momo (whilst more expensive) was the only one I felt fitted properly and would be happy to use - based on the number of threads left showing that the central nut would tighten onto and the overall quality.
 m http://www.demon-tweeks.co.uk/performan ... l-boss-kit m
Miles,
Many thanks for your reply. I don't mind spending the money if it's good quality.
Just one more question if you don't mind: Did you also get the airbag light cancel 'kit' from DT?
Standard
I have a Momo boss kit (MK7733R I think) that cancels the indicators on my PFL. I think I paid £78(ish) delivered.
It comes with everything you need including the resistor to stop the airbag light staying on. Bear in mind that you may need to account for a horn button when buying a wheel. The instructions that are included are pretty poor imo.
Quite a simple job really and took me around an hour (and I'm rubbish with a spanner).
However you will need a different kind of boss for that wheel as the screw figments are positioned in a different place on the wheel... I think it's a nardi boss you will need.   s:?: :?: s:?:
MilesH
Quote from: "Alex Knight"Miles,
No, I just bought a 5p 3.3ohm resistor from Maplins  s:) :) s:)
Thanks all for the replies.
I will go with the Momo.
One last question!
Does anyone know the diameter of the standard steering wheel?
Trying to decide on a 330mm or a 350mm!
Standard
It is 350mm for the standard wheel.
Don't forget if you want that particular wheel that you pictures you will need a different boss as the fitment is less common.
Thank you for that.
You can get a PCD adapter to allow fitment of Personal/Nardi wheels to momo bosses:
 m http://www.demon-tweeks.co.uk/motorspor ... ring-wheel m
I'll go for the 330mm then.
