Missfire
Started by Steveohim, May 11, 2016, 07:31
Steveohim
#50
I've read a post on here about a guy with the same problem, turned out it was an injector, can anyone recommend a good place to get one?
#51
I'd be inclined to do the 3-4 swap just to confirm that it is in fact an injector issue, but up to you. Its the next logical zero-cost option towards getting a diagnosis.
Any idea why the injectors needed to be replaced previously on cyls 2&3? There might be some clues there.
An ad in the ROC's wanted forum should get you a replacement that works. I've got a bucket full of them here, I'm sure others have too. Don't spend too much - a friendly member should see you right for £15 delivered, tops.
If you're going down this route, I also recommend you pop into a Toyota dealership and order the seat and O-ring seals for top and bottom of the injector. They really hate being re-used when they're old.
Steveohim
#52
I've got it booked in for next sat, he has some refurb injectors, no idea why the other injectors failed doesn't say on paperwork
Steveohim
#53
All sorted, was the injector
