0 Members and 11 Guests are viewing this topic.
Took the centre bolt out of the rear mount, access was nice and easy... Then thought that I should take the mount off the rear subframe... But then realised that I should just crack on and take the subframe off...
I just have one snag- I'm trying to leave the arms attached to the subframe, and that means undoing at the wheels. However I can't get the control arm off the hub, I don't know if it's because I have the hub supported on a stand or if it's really tight....
Is there a technique to it? I don't want to destroy the rubber...
Finally- lessons learnt.
GET A FLOOR CREEPER! my word it made working tonight so much nicer....
The jackstands under the hubs not the best location.
Put the here:  (and then get at the bolts with your breaker bar.
Also - don't forget to disconnect the ABS wires.  Connectors behind where the lighst were.   Disconnect, pull through and take off the bracket holding the wire to the subframe.
Yeah bit of a problem the ABS sensors...
Undid the 10mm, and it's totally seized in there... The plastic retainer actually split as I tried to lift it out..
Any suggestions?
Quote from: Carolyn on August 26, 2018, 09:12
jonbill
Are you trying to remove it from the hub John?
Yup, undid the 10mm, then tried to prise it upwards with a flat head screwdriver...
I've undone the bolt that holds the abs cable to the body so it's got some play..
Is it essential to disconnect?
Quote from: jonbill on August 26, 2018, 09:35
Oh wait.. Just re read Carolyn's post!
So there's connections behind the lights!
Sorry . Will go check...
Don't try to remove it from the hub -you'll only destroy it.  (£50 a pop!!).
Just disconnect it and tie the lead up so you don't damage the wiring and plug.
Quote from: Carolyn on August 26, 2018, 09:54
Thanks Carolyn and Jonbill...
Couldn't see the wood for trees there for s second...
Yeah problem solved!
Hopefully I've not broken the sensor...
jonbill
I made that mistake when I did mine in 2016. The banging about also broke the reluctor ring[emoji22]
I need to give you a visit!
Get those caliper carriers and discs off.  Utterly in your way!
Err how much banging we talking here?
Quote from: jonbill on August 26, 2018, 09:59
You're always welcome Carolyn...I work most nights on the car... Next "day" on the car will be Monday morning and Tuesday full day.
Quote from: Carolyn on August 26, 2018, 10:03
jonbill
Quote from: jvanzyl on August 26, 2018, 10:06
Ooh a lot. I'm sure yours will be fine.
tomaky
Bit late but possible dolly for others.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
May still need it...
Quote from: tomaky on August 26, 2018, 12:10
Ok. Well I was gently trying to tap a flat head under the plastic thing when it split... So I'm hoping the sensor is fine.
Quote from: jonbill on August 26, 2018, 11:57
tomaky
Aldi ;)
Westfield Seiw
Ex - 2003 Sable
Abs wires disconnected and tucked away, brakes all removed...
New point of frustration is this arm which I cannot seem to pry away from the hub...I can only seem to get it a mm or two along!! [emoji19]
Stuff it.
Down it goes...
Well.... It's down!
Wasn't the smoothest of downward journeys.. Gear cables got caught up, the occasional scraping sound was heard and my ability to carefully turn the release valve on the crane is somewhat lacking!
Anyway... It's down and tomorrow morning I'll try and get it out and then start taking bit off it!
One thing I've found and I don't know if others feel the same way- it's nice doing all this, but I can't help feel that it'd be a lot more fun with someone else! I shall have to find ways of getting the wife involved....
jonbill
Quote from: jvanzyl on August 27, 2018, 00:07
Well.... It's down!
If you do it all yourself, you don't have to share the glory.
GazMav
How come you took the subframe off?
Mini pallet with 4 caster wheels. Jack underneath to support engine and use crane to life car (remove front bumper).
GazMav
Like this...
