02 sensors
Started by goneroming, September 25, 2016, 10:39
goneroming
On my jap import mk3 2000 it has only two sensors on the manifold & none on the cat. Is this correct, because I cannot see where there is another connection for one. I have just fitted new stainless manifold & new cat where there is a connection point for a sensor. The old cat did not have sensor.
All is well JDM cars only have 2 senors.
They also use JOBD instead of ODB2 making it a little trickier to read error codes from the ecu.
You probably have shorter gearing too i think.
Not sure about LSD.
Courtesy of HFB:
RESULT!
With this
 m http://www.ebay.co.uk/itm/321660728028 m ? ... EBIDX%3AIT
Purchasing Torque Pro on my android for £5.00
and the addition of this line of info in the simple to use profile update (just a simple typing in one line of info and saving when setting up a car profile) - 3rd post down in the thread
 m http://www.mr2.com/forums/threads/92691 m  ... on-jdm-ecu!
And I now have a blue tooth OBD2 reader that provides all code info, clearing code facility and engine info in realtime on my MRS import.
HFB
