2zz fault codes PO171 and PO420
Started by mikek, September 25, 2016, 12:23
mikek
Im having a couple of issues with my 2ZZ conversion. Apart from the misfire fault codes caused by the stage 2 cams i am also getting the following codes....PO171 running lean bank 1 and PO420 inefficient cat bank 1. I have installed a sports cat and Janspeed exhaust since the conversion but i dont think this would lead to it running lean. Any ideas?
Mike
2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
headcase
clean your maf and space rear lambda sensor out of stream of gases
mikek
Thanks. I've cleaned the maf. Do I just buy a spacer for the O2 sensors? Do I space both or just post cat?
I've been running a £3 resistor from Maplins to cure P0420 on my 2ZZ. Do a search on here.
The post cat sensor is only there to check cat efficiency, has nothing to do with fuelling. You basically don't need it.
mikek
Would that solve the running lean issue aswell?
Quote from: "mikek"Would that solve the running lean issue aswell?
No. They re separate issues.
mikek
I thought as much. However they appeared at the same time, after I changed the cat and exhaust. Is it therefore running lean because it's shifting more air now the exhaust is free flowing? How do I sort this out?
A few things to try are:
Check for exhaust leaks
Clean MAF sensor
Check injector voltages
Replace O2 sensor
