ABS problem
Started by schaffo2, March 13, 2017, 11:07
schaffo2
Hi every one
I've had a misread on the car and found errors on Abs system.
there are 2 errors
error1 co 273 supply voltage to the pump motor
error2 co 226 solenoid valves right in front of interruption / short circuit
checked the fuses but the book says no 48 I can not find
thanks jørgen  s:D :D s:D
Not sure if this helps.
But there are some hidden fuses at the end of the facia/dash. Only visible when the doors are open.
Over here it is on the passenger side.
