Low conpression after engine build vvti ?
Started by ilovejapcrap, July 11, 2017, 10:46
ilovejapcrap
Well they seem ok
I'm so annoyed at moment can't seem to find an issue !
I'm assuming others have used after market head gasket with no issues !
yes several times.
Yes several times.  I doubt a dodgy head gasket would give such massive low compression on its own, (You might get a coolant leak, or some other problem that may surface in a running engine) but not 70 psi in two cylinders. Either: The valves weren't sealing, the rings aren't doing their job, one of the surfaces (head or block) isn't flat, or the head was not bolted down properly.
Is a liner sticking up??
Were the very low readings in adjacent cylinders?
Are the rings phased correctly?  (Though I doubt that would cause your symptoms).
You're not going to like this:  Are you sure your compression test was accurate?  Had to ask.
ilovejapcrap
Hello all
The original test was 100 130 70 70 for compression.
I then leak down tested it at like 1.5 bar and all came back as ok in that test. Odd not sure how good a leak down is.
I took the head off and checked it all out and could find nowt wrong.
I then put head back in using old bolts and gasket for a check and had 0 compression on test
So I figured oh gaskets not re sealed but thinking now after a major break from it I did not have all timing chain back on so it would not open valves to allow air in to them compress !
Anyway I have removed head again and measured the internal bore. They seem ok.
In order to try and prevent taking bottom half of engine back to bits I've ordered a set of RIK pistons same as ones I installed.
So I can do rig gap test without taking it to bits ( assuming they are same as what Ive installed ) should be.
If that comes back ok I'm checking top of block for flatness.
If that comes back ok I'm sending head off for a full rebuild new gasket and bolts and putting back together.
Fingers crossed it's a warped head of faulty gasket !
jonbill
Lucky it's a non interference engine! [emoji12]
ilovejapcrap
Hehe
SteveJ
Don't assume that's correct - several people have reported the last gen (8-hole) pistons did in fact hit the valves when tested.
For the record Toyota specify the 1ZZ IS an interference engine design.
Quote from: "jonbill"Lucky it's a non interference engine! [emoji12]
Your subtlety is only exceeded by your forbearance.
ilovejapcrap
Well without the cams on valves are shut anyway
Anyway taking head for checking and skimming tomorrow.
What gaskets has everyone used ?
jonbill
I used the standard mls gasket from the MAG rebuild lit.
ilovejapcrap
#36
Hello all.
Quick update I have had full rebuild on head re skimmed valves lapped again and shins ( or whatever you call them) checked.
They say it had a few minor issues but doubt it would cause my issue.
I have also checked the spate rings in bite and all are well within tolerance.
The gasket I used was a Certain make and the head shop says they have had a couple of issues with them. I have got a different make that they advised !
So time will tell
Good luck!
smarty72
Fingers crossed for you...
current: Astral Black FL
Ex: Forest Green 2003.
ilovejapcrap
It runs !
Looking very strongly that the headgasket was my main issue allowing venting between bores
ilovejapcrap
Sweet! Well done
smarty72
#42
Hooray
jonbill
#43
Well done - reward for perseverance!
Got there!  Good show.
cabbydave
#45
I would only use genuine head gasketson Toyotas. I learnt that one back in the days I was running a mk. Come to think about it I still have one
