Charcoal canister removal
Started by m1tch, July 16, 2017, 21:47
m1tch
Hi all,
Just wondering what I need to do to remove the charcoal canister, its 14 years old and I am pretty sure its well past it, looking to remove it to clean up the engine bay a bit and lose some weight, I will look to run breathers on the cam cover, I am guessing that there is a fuel tank vent somewhere as well.
Just wondering how best to go about removing it and plumbing the pipework in.
ilovejapcrap
the fuel tank vents into this I think
m1tch
Yeah the canister should have inputs for the PCV breather system from the cam cover as well as the fuel tank vent - just wondering what the usual reroute is when removing the canister, on the MX5 you can usually loop the lines or vent to atmosphere.
The canister has a vacuum input that comes (via the solenoid valve mounted on the big rubber inlet tube) from the inlet manifold.  If you remove the canister , remove the solenoid and block off the tube that goes to it from the engine.  Don't block the other tube to the canister as that is the breather for the petrol tank.
m1tch
Quote from: "Carolyn"The canister has a vacuum input that comes (via the solenoid valve mounted on the big rubber inlet tube) from the inlet manifold.  If you remove the canister , remove the solenoid and block off the tube that goes to it from the engine.  Don't block the other tube to the canister as that is the breather for the petrol tank.
Thanks Carolyn, I will check the pipework in the engine bay, I could see the solenoid and various pipework around the engine bay but just needed to check how best to go about it - will probably remove the setup tonight or when I fit the new induction kit.
Or extend the breather from the fuel tank to the rear bumper,add a check valve and put the solenoid on with a 12v feed with a button.
Then u kan makez da flamez and be cool like the all the cool kidz. In it.
...don't do this..
Quote from: "shnazzle"Or extend the breather from the fuel tank to the rear bumper,add a check valve and put the solenoid on with a 12v feed with a button.
...don't do this..
He gives and he taketh away....
m1tch
...don't do this..
ZOMGZ KOOLZ, Will do dis!
Maybe not  s:P :P s:P
Will look to remove and reroute/blank the various parts of the system, will also be interesting to see how much the setup weighs as I know there is the canister as well as some hardline as well.
SteveJ
IIRC, only the US cars have a charcoal canister and it is mounted underneath the storage bins. The unit in the engine bay is a trap to prevent fuel being drawn into the intake when the tank is filled up the neck and the solenoid opens.
[edit] You'll save more weight by not having a bacon-batch (or at least recycling it  s;) ;) s;)  ) before doing a 1/4mile run than you will removing the canister in the engine bay. [/edit]
m1tch
Quote from: "SteveJ"IIRC, only the US cars have a charcoal canister and it is mounted underneath the storage bins. The unit in the engine bay is a trap to prevent fuel being drawn into the intake when the tank is filled up the neck and the solenoid opens.
Ah, so its not a charcoal canister, but its still part of the emissions system, will be careful when removing and plugging the pipework etc, more interested to see how much the setup weighs though, it does all add up, driver weight will also be reduced further.
m1tch
After seeing leethesparky remove the canister from the side of the engine bay I thought I would also look into it, it would seem I could simply connect up a line between the tank breather pipe and the solenoid. However after pulling the canister out (it weights around 750g) I noticed that one side is actually a cap that can be removed meaning that its already venting gasses into the engine bay owing to having just a foam seal rather than an air tight seal.
Would it be ok to remove the whole setup between the canister and the intake including the solenoid and simply vent the tank to atmosphere - maybe run a line to behind the rear light? I would need to block off the throttlebody as well to prevent an air leak but it would tidy eveything up.
Many have done just that.  Perhaps leave the hose from the throttle body and plug that?  Never know when you might want the vacuum.
m1tch
Quote from: "Carolyn"Many have done just that.  Perhaps leave the hose from the throttle body and plug that?  Never know when you might want the vacuum.
Thanks for that, I will look to do the mod tonight then and see how much it all comes to - always best to remove weight off the rear now the frunk is empty! Will remove the canister, hard line and solenoid and then plug the pipe to use as a vacuum source, will then run a pipe from the tank vent pipe to the rear.
ChrisGB
An open tank vent will leave your car smelling strongly of fuel, I'd suggest plumbing in something like this:
https://www.newton-equipment.com/tank-vent-valves-inline-tank-valve-model-tpv8.html
Makes a big difference!
m1tch
Quote from: "ChrisGB"An open tank vent will leave your car smelling strongly of fuel, I'd suggest plumbing in something like this:
 m https://www.newton-equipment.com/tank-v ... -tpv8.html m
Ah, am I correct to say that those are 1 way valves which then open when the tank gets to a certain pressure?
ChrisGB
Sort of, it opens to prevent vacuum in the tank when you are using fuel and it vents pressure in the tank with temperature changes.
m1tch
Quote from: "ChrisGB"Sort of, it opens to prevent vacuum in the tank when you are using fuel and it vents pressure in the tank with temperature changes.
Cool, will check the diameter of the vent pipework later tonight - would something like those bike tank breather valves work? Or could I simply use a small inline fuel filter which will allow the tank to vent but reduce the fuel vapor smell etc?
ChrisGB
Quote from: "m1tch"
Possibly, I always ran bikes open breather and anti spill valve.
m1tch
Quote from: "m1tch"
Cool, they are only a few £s so will try that first and see what its like.
at what point will the VSV purge fuel fumes into the intake? Just on start up? On cold? What are the negative effects to removing this system.
Also, will the removal of the solenoid cause a CEL, as it is ECU-driven?
m1tch
Quote from: "shnazzle"at what point will the VSV purge fuel fumes into the intake? Just on start up? On cold? What are the negative effects to removing this system.
I am guessing that it would purge when on cruise as adding in fuel rich vapour would cause issues if the engine is under load etc, I was expecting multiple lines going into that tank but it seems its only for the tank vent, I doubt that after 14 years any active ingredient in the tank is doing anything.
I am guessing it might through a CEL, I will run with it unplugged next time and see if it throws something, guessing it would usually flag that something isn't working - I guess it could simply be kept connected for the ECU to be happy its still attached.
ChrisGB
Quote from: "shnazzle"I'll get thus one post-pay-day
http://www.demon-tweeks.co.uk/Product.do?method=view&n=1546&p=23336&d=124&c=4&l=2&utm_source=Google&utm_medium=Base&utm_campaign=Fuel%20Tank%20Vent%20Valves&gclid=CjwKCAjw_dTMBRBHEiwApIzn_N2Le9aQ4K2CiI_3kkSq3ZOotBMlfaZbFiVcE-92kFk4brb0XC_qJBoC3mcQAvD_BwE
Quite pricey, Merlin Motorsport have them for less. Cannot remember where I bought mine, it was a company recommend by Newton Equipment and it was about £35.
As mentioned on the what did you do thread, it seems there are a few holes in the removal of this.
Fuel vapours, fuel pushed up by pressure, collapsing tanks, etc etc. P0446 code for the evap system if disconnected...
All seems a bit of a faf for the sake of a tidier engine bay
ChrisGB
Have to say, I wouldn't remove it without good reason.
