emissions
Started by davethediscoman, March 22, 2018, 21:13
davethediscoman
hi ,what could cause these readings.
fast idle co 2.99%
             hc 876 ppm
             0.914
2nd fast idle      co 1.76
                        hc250 ppm
                        0.951
jonbill
It's what Carolyn said.
If you replace the cat you might get through the MOT for another few years.
mot fail high emissions
https://r.tapatalk.com/shareLink?share_fid=15578&share_tid=64784&url=https%3A%2F%2Fwww%2Emr2roc%2Eorg%2Fforum%2Findex%2Ephp%3Ftopic%3D64784&share_type=t
davethediscoman
what happens to the cat does it just get clogged up ?
Aside to Carolynne's earlier sound advice, do you still have the pre cats in the exhaust manifold?
Regarding your question though, cats are mainly ceramic inside, the oil clogs the ceramic pores and stops them "converting".
davethediscoman
to be honest i dont know much about the car engine ect i just like to drive it .
Quote from: davethediscoman on March 22, 2018, 21:50
That's a fair comment [emoji38]
delhusband
In a similar position my good man, you're not alone :)
Hate pointy animals
Quote from: delhusband on March 22, 2018, 23:08
Err? You Sir, know more than enough!
Dave
Where you based?
Dave, check out 'Cats2U'.  £120 -£130 depending on offer... for replacement cat.  Quite a few members have used them with good results.
davethediscoman
Hi,and thank you all for. You sound advice.i am based nr Canterbury. Am I right that the cat that's the problem is the middle section of exhaust?. I have a friend that works in trade that can get a good quality one for£ 98 plus vat.
Quote from: davethediscoman on March 23, 2018, 17:13
Cats2u current price is £130 plus £9 delivery but that includes a fitting kit they sell separately for £18 so it depends if you're getting the same fitting kit from your friend?
jonbill
Yes the cat is the section before the large silencer.
£98 is a good price.
jonbill
Yes thats the one.
davethediscoman
Just to throw in this, it's now throwing a fault code for O2 sensor. On pre cat. Would this now be telling me that that could now be problem, or is it part of what we have already talked about?
Quote from: davethediscoman on March 24, 2018, 11:53
If you haven't already Dave, have a read through the information in the workshop.
Forums-workshop-maintenance precats etc. It'll give you an idea of the common problems, causes and fixes.
After that you'll have a better idea of the questions you still need answers to.
I'd get yourself an OBD2 code reader too, very inexpensive and worth the weight in gold.
Quote from: Call the midlife! on March 24, 2018, 12:48
I suspect Dave has a code reader, as I can't think how else he'd know it's a sensor fault.
Dave: post the fault number so we can assist.
Quote from: Carolyn on March 24, 2018, 13:19
True, I've been spending money this morning, it always tires me out [emoji23]
davethediscoman
Yes I have a code reader, I cleared the codes and since they have not come up again. So I don't know what or why it did do that this morning.
Quote from: davethediscoman on March 24, 2018, 18:17
Can sometimes take a couple of drives for the ECU to decide it's still not happy so don't be surprised if it comes back.
Can you remember what the code was?
davethediscoman
davethediscoman
It takes me to the net to find it. Pre cat sensor it was saying.
Quote from: davethediscoman on March 24, 2018, 19:23
Depends on the actual code really, wether the actual sensor is fubar or the heater that comes on until the exhaust gases warm it up enough to work properly.
I'm far from expert but I wouldn't think one failed O2 sensor would give you those emissions, especially if it's nice and hot.
Lumps of degrading pre cat might give duff O2 readings but that's a different story.
Duff o2 can most certainly make you fail MOT. Easily.
High HC is running rich (or stupid lean), if o2 sensor is reading lean incorrectly, it will be telling the ecu to dump fuel in,making it run rich as hell and give you insane hc levels like 800+
