All sorted
Started by wotugonado, May 5, 2019, 18:35
wotugonado
A rear brake caliper carrier to hub bolt going begging?
My caliper bolt has sheared off in the carrier and now the carrier hub bolt has rounded trying to get the f@#*ing thing off to drill out the original broken bolt. I have a spare caliper bolt but desperately need the carrier bolt as the mot is rapidly approaching.
Also are irwins bolt removers any good?
I bet the swear jar at yours is overflowing mate!! Hang in there!!
I don't have a bolt, but I do have a set of irwins that saw me right when I used them. I'd recommend them.
wotugonado
Yep and there's still not enough money in jar... It's turning into an expensive little pre mot brake adjustment.
Irwins and new bolt needed and now front discs, I just love mot time :)
Quote from: wotugonado on May  6, 2019, 15:56
You are welcome collect my irwins if you are desperate. Perhaps on your way to Rutland for your bolts!!! ;)
@Topdownman has 1 front disc if you need it!! ;) ;)
wotugonado
@StuC
Thanks for the offer pal, but I've ordered some now (worth having when dealing with these old sh1tty bolts) and got the new bolts on order from Mr2 Ben.
Quote from: wotugonado on May  6, 2019, 17:00
@StuC
No probs fella. Glad you have a plan in action. :)
wotugonado
Time is of the essence, I was hoping someone localish to me might of had one so I could crack on today, but wasn't to be.
So instead Ive had to lounge around watching GOT :)
