Injector O rings
Started by ad_car_08, May 6, 2019, 23:21
ad_car_08
Was going to attempt to fit the 2zz yellow injectors earlier. Whilst looking for a "How to" I read that some replacement o rings are recommended.
Does anyone know where id get them from, to fit the yellow injectors? Apparently they're slightly thicker than those needed for the 1zz green injectors?
[/size]
I've found that they are interchangeable.  When they come as part of kits, there is no difference that I've seen.  Never had any leaks after swapping injectors.
Older O rings will look a bit thinner as they deform over time.
You can get them from Sealforce (they have an ebay shop).  I bought 8mm x 2mm Nitrile. (fuel resistant).  Might as well buy a few 'cos they're so cheap!!!
Only difference I noticed when I got the 2zz injectors was the colour, orange rings on the 2zz ones. I got some new black ones with the full engine seal kit for the rebuild and they didn't leak on the 2zzs when I fitted them.
ad_car_08
Quote from: Carolyn on May  7, 2019, 09:34
Is this the only size i'd require?
[/size]
Quote from: ad_car_08 on May  7, 2019, 16:42
So long as you don't need the fat base seals as well.
ad_car_08
Worth getting as a belt and braces approach? I don't fancy risking any kind of leaks.
I see sealforve are on holiday and not taking orders, so I looked on fleabay...99p per o ring?...Is that right?
[/size]
Quote from: ad_car_08 on May  8, 2019, 10:00
Check the price for ten!!
If the base rubbers are flexible, they'll be fine.  They seal air not fuel.  If they've gone stiff, might be worth getting a set (won't be from Sealforce though).
Essex2Visuvesi
How many do you need?
I have some of the seals that Carolyn uses.... she was kind enough to give them to me a while back when I was doing the turbo build
Happy to post them to you FOC if you need them.... think there's a set of 4, but will need to double check
ad_car_08
Quote from: Essex2Visuvesi on May  8, 2019, 13:14
That's very kind of you, thank you! If I just need 1 seal per injector, just the 4 please  :notworthy:
[/size]
Essex2Visuvesi
No worries, I'll dig them out tonight... might actually be at home for a change
