Car starts, dies under load
Started by Stag, September 5, 2019, 15:35
Stag
Quote from: shnazzle on September  7, 2019, 21:40Bit weird without any metrics at all, leaving you with trial/error.
When it idles, it idles OK. No bumbling or obvious misfiring.
So we've got fuel and spark.
At first start and idle it has no o2 feedback at all, so it's running "dumb" off the ecu.
The car has mechanisms to protect against MAF failure; engine vacuum measurement. Its last hope for knowing how much fuel to put in. As fuel goes in and timing changes, revs rise, which changes vacuum.
That's why my thought goes to MAF.
Unplugging maf does little. Tell tale sign for any sensor. If you remove it and there's no or little change, it's probably duff.
Big unknown is the harness. It could have been nicked during removal etc.
Do you have an OBD2 dongle and android phone? Or iPhone and WiFi obd2 dongle?
I have a obd reader, just a cheap one from euro car parts. Did the job before but now when ever I try to read anything I just get "link error"
Swapping the harness over a good place to start ?
Quote from: Stag on September  7, 2019, 21:55
If you can pull the engine out of the car, swap harness, and put back in in the time you have..... Then still no :)
The obd2 not working is very suspect.... Is there any way you can get the part number printed on the ecu?
Stag
Quote from: shnazzle on September  7, 2019, 22:00
That the one ?
Stag
Definitely an EU spec ecu. Pre-fl.
Is that your old ecu? Or is it a replacement?
Stag
Quote from: shnazzle on September  7, 2019, 22:26Definitely an EU spec ecu. Pre-fl.
It's the same eu that was in the car. Only thing that's changed is the engine, did new clutch and belt n pump while I was in there
normanh
Stag
Little update, removing the maf sensor, allows me to rev freely no lag in revs second I put my foot down it revs instantly. But only up to 3k, does this solve it ? Is it for sure the maf ?
Quote from: Stag on September  8, 2019, 14:38Little update, removing the maf sensor, allows me to rev freely no lag in revs second I put my foot down it revs instantly. But only up to 3k, does this solve it ? Is it for sure the maf ?
It is rather suspicious isn't it? :)
Contact Dick Sloan @dick2ski or Dean for a 2nd hand. Dick will ship it very quickly if asked.
Stag
Quote from: shnazzle on September  8, 2019, 14:41
When I click on dicks @ you provided he's not been online since may and has 1 post ?
Quote from: Stag on September  8, 2019, 14:50
Sorry, yes, that's correct. His contact details are in the breakers section in the marketplace. Givr him a call. If he's got one he 'll post it today if he can
Bloody well looks like it to me!!
Stag
Huge thank you to both @Carolyn and @shnazzle you've both been a massive help, I'll update you once I get a new maf in her
When it arrives. Give it a clean with your spray of choice.
Bear in mind the 2 delicate wires hidden from view. Spray but don't touch.
Depending on the spray used. The O ring can react and go a bit "baggy" (technical term)
Best to GENTLY remove O ring 1st. Spray -dry - refit.
Might as well pull the ECU fuse whilst doing this to reset. So when all back together, starting from a stock position.
Yep.
2 Toyota's and a lexus.
The 2, a 1.5 Prius and a 3.3 v6 rx400h.
All the same maf.
Stag
So I spoke to dick, he said he can send me one out, asked where I was. Turns out he was in my town yesterday collecting a mr2 off someone that lives in my town.
Long story short, the guy he collected it off has one, he's only 5 mins away.
We will have some answers tomorrow boys
Quote from: Stag on September  8, 2019, 20:45So I spoke to dick, he said he can send me one out, asked where I was. Turns out he was in my town yesterday collecting a mr2 off someone that lives in my town.
Nice! What are the odds of that? :) Gotta love the '2 community eh?
Quote from: Ardent on September  8, 2019, 21:48
Quote from: Stag on December 20, 1974, 18:46We will have some answers tomorrow boys
And girls
Let's not forget the girls.
We have several.
Stag
New maf in, Suprise suprise its STILL not working
Oh dear....
Back to finding a ground/wiring fault it would seem.
Stag
Quote from: Carolyn on September  9, 2019, 13:59Oh dear....
How big of a job is swapping the looms over ?
Bit of a bugger, but it's been done before.
Some people (who hadn't been told any different) have taken the loom off for and engine-out and then put it back on when the engine was back in.  The hardest bit is underneath (especially between the inlet manifold and block).
Have you tried spraying out and blowing out the MAF connector and checking pins?  Worth a look?
Stag
Will get back to you, Need some more  contact cleaner from ECP. Give it a clean
