Gear Cage Mounts
Started by steeleyscoot, April 8, 2021, 20:32
steeleyscoot
Hi All,
Has anyone got a set of Steve's (Widermuller) excellent Gear Cage Mounts they are willing to part with please..?
I did setup a Group Buy last year, but I think Steve has been too busy with more important things in his life to tackle.
So it's a long-shot but if anyone has some and are willing to sell them, then please drop me a line.
Cheers,
Dave.
Quote from: steeleyscoot on April  8, 2021, 20:32Hi All,
Cheers,
Dave.
@Topdownman
Simon didn't you bypass the mount and screw yours direct to the body?
steeleyscoot
Mmm... by mounting directly, are you not likely to introduce play over time by the bolts chafing/moving in the nylon cage..?
I recall Steve's aluminium mounts were 'inserted' into the nylon cage thereby acting as a sleeve surrounding the retaining bolts..
Yes, I just took the rubber mounted bushes off and screwed direct to the floor so it was solid. This takes out the play that you get in the normal set up so the gearchange is better.
The rubber bushes are just there to reduce NVH and make the car seem more upmarket I suppose but its a compromise like everything and makes the gearchange less precise.
If you want to get some height then you can just make up your own spacers out of anything light but rigid that you may have to hand as they are hidden by the centre console so doesnt matter how **** they look as no one can see them!
Having lovely hand made spacers is a waste when no one knows they are there really.
(And easy to put back the rubber bushes if you dont feel that its better).
If you really, really want some alloy spacers though, you get them wth the ebay short shift kits if you can still get them?
Mine has been like that for something like 5 years with no issues as far as I know.
steeleyscoot
Thanks for the feedback guys.
If you look up BRD (Brookes Racing Development) I'm sure Lou Brookes makes some poly ones that do the same job if you definitely want to keep some form of spacer/bush under the cage.
andyroo104
Cheers,
Dave.
I may have a set in the garage if still needed.
McMr2
Quote from: Topdownman on April  8, 2021, 21:27Yes, I just took the rubber mounted bushes off and screwed direct to the floor so it was solid. This takes out the play that you get in the normal set up so the gearchange is better.
Been running with it for 3 years like this, bit more fizz in the gearstick but feels solid.
2004 Silver. Stock(ish).
J88TEO
Quote from: andyroo104 on April  9, 2021, 16:52
Cheers,
Dave.
I am interested if OP pass on this one.
Cheers.
steeleyscoot
Cheers,
Dave.
Cheers,
Dave.
PM sent
andyroo104
wotugonado
@steeleyscoot
@J88TEO
Ive just found a set of these after my garage clear out, if either of you are still interested.
@ me on here to let me know
J88TEO
Quote from: wotugonado on May 20, 2021, 17:59@steeleyscoot
@J88TEO
Yes please...how much please?
wotugonado
Quote from: J88TEO on May 21, 2021, 22:42
@J88TEO
I have no clue, I'll look at p&p and get back to you.
wotugonado
@J88TEO
Pm'd you
J88TEO
Thanks.
I will take these.
Cheers.
wotugonado
ralf321
Can anyone tell me tell me how thick they are ? I will get mine out of my 3D printer.
BR
Ralf
There is no need to overthink this, all you are doing is raising the gearlever up a bit so there is no right or wrong. You could probably make some out of an old broom handle! The only reason you need these is if the shiftlever is too far away from you.
I have a couple of the ones from the short shift kit to hand and they raise the cage 12mm and about 35mm across (not the best picture!);
The top portion just locates them in the cage. Unfortunately I couldnt find the original ones as a comparison but I dont think they actually raise the cage up much.
ralf321
OK, thank you. I printed them out and they fit nicely so far. I used PETG with 80% infill. Curious how it feels once installed.
Just watched this video;
https://www.youtube.com/watch?v=SMin4Jz1GRc
Towards the end he shows his home printed new mounts. He includes some before and after clips so you can see exactly why you may want to take out the oem bushes!
Very easy to just remove the oems and bolt straight to the floor to try it without and if you think you need more height, you can then look at your spacer options. Easy to put the oems back too if you dont like the feel of more direct shifts!
