Anyone running a square set up on 15"?
Started by Smithy, April 11, 2021, 10:24
Generally yes.
But specific tyre info would be required say properly.
Are they standard or XL tyres?
Chilli Girl
Yep, mine were 26 fr, 32 r but they were stock facelift sizes, 15 fr,16 r.
What is the load rating on the tires?
Erm you didn't have oem wheels... oem FL wheels are 16 rear and 15 front.
Please do share a pic.
Glad you're doing better anyway.
Quote from: jvanzyl on May  4, 2021, 19:17Erm you didn't have oem wheels... oem FL wheels are 16 rear and 15 front.
I thought that until recently when I noticed this:
https://www.mr2roc.org/forum/index.php?msg=851547
 I mentioned the 5 wheel nuts and the Roll Bar but neglected to mention the 17 inch wheel " options" that I guess makes them Optional OE
Smithy
I will get a better picture tonight but this is my car as I bought it. 17" rear and 16" front.
03 Astral black MR2 OEM+
AdamR28
I'm running square on 14s. All good.
On a tráck car Adam. Just a detail, I know, but still ;-)
Quote from: Smithy on May  5, 2021, 11:57I will get a better picture tonight but this is my car as I bought it. 17" rear and 16" front.
 That is a FL car with 15/16 wheels.  Oddly enough the rear 16" OEM wheels is very heavy compared to the 15" wheels for the PFL and a good number of  17" aftermarket wheels.
AdamR28
No reason it wouldn't work just fine on the road, though.
Quote from: AdamR28 on May  6, 2021, 07:36No reason it wouldn't work just fine on the road, though.
Ground clearance?
That observed it is thé easiest solution to a bit lower gearing and the lightest wheels.
AdamR28
Fair point.
Though assuming 185/60R14 tyres, a common size for 14" wheels, that would only drop ride height low single figures of mm.
Quote from: AdamR28 on May  6, 2021, 08:53Fair point.
Aye, but I don´t live on a smooth track but at the end of a dirt track with green strip in the middle :-)
When I bought the car I could not get home. Needed to kleave it at the bridge and do a week of hard shovelling hardpack to fill in the track a bit. Also cropping the green short a dozen times/year.
At its very, VÉRY best it is
and nów it it 20-25 mm lower on Sportivo kit :-O
Also getting on/off tarmac is more often than not a 10 cm. step. About half the time the parking is an unbuilt barren plot hardly suited for any road car.
Never mind getting in/out underground parking lots crossing the ideal.
AdamR28
Don't lower your car then, simples ;)
Quote from: AdamR28 on May  6, 2021, 11:03Don't lower your car then, simples ;)
Why didn't I think of that?
