My black 55
Started by WesOCP, May 13, 2021, 14:27
WesOCP
Much like Trigger's broom & most of Marvin, I'm finding myself replacing more and more bits on my 55 plate, just to keep it on the road.
So I thought I might start a photo log of it as I've done some stuff on it recently.
Here we are on day 1, fresh from the dealer and on our way to the Lakes for some wintery driving
WesOCP
First job was getting the brakes renewed, so got a set of these
Someone kindly scraped it outside the house & didn't bother telling me
So I got these and did a bit of this
In between we do a bit of this
and this
WesOCP
My band went to Japan and I saw a couple of worthy mentions around Tokyo, not much out in the sticks though
WesOCP
(After an inordinate amount of tidying) managed to squeeze it in the garage, not much working room though
Me and Bob managed to get the handbrake cables replaced in there though, hi Bob
WesOCP
I've lost count of how many times I've done this
I'm guessing this time was to install an amp under the rear bins to power this
WesOCP
This was an easy one, although getting it delivered over Xmas proved tricky
WesOCP
Found this little fella lurking on a rear corner, so swapped them all out.
(Better half chose the colour)
WesOCP
As you'll have spotted on the handbrake cable replacement, things were getting a bit rusty down there
WesOCP
So (at least) two birds with one stone, let's crack on with the clutch it's needed for a while. Following the thread on here and help from the pics on the FB one, it wasn't too difficult. No snapped bolts, no cutting, and only one quick blast with heat to tackle the spinning ball joint.
Nice new LUK on the right - s**t out of luck on the left
Lots of cleaning & replacing as we go
Easy peasy
Quote from: WesOCP on May 13, 2021, 14:55This was an easy one, although getting it delivered over Xmas proved tricky
If that is a Coolparts radiator the design has changed from the one I bought a few years ago. Mine has a small "pipe" on the top of the nearside vertical header that was blanked off as it was of no use.
The fact is whatever was blanking it stopped doing so and discharged all of my
( expensive) Mr T long life coolant.
Glad to see the protuberance  is no longer a feature.
WesOCP
Although I only needed to take the nearside suspension apart, once I saw how rusty everything was I stripped both sides.
Yeah, glutton for punishment
Twisted wire attachment on the drill didn't do a bad job, but not good enough either
One bottle of magic pixie dust later
and they're like new!
Couple of sploshes of hammerite and they're good for a bit longer
WesOCP
Yeah yeah, but how's your crossmember?
Fine thought I
Until I took it off for a tidy up
So quick call to Paul at TCB and we're back in business.
Coated with wax inside & out, painted with hammerite twice, and fingers crossed for another 15 years
And we're all back together, up and running, and about 75% less brown
WesOCP
Next up - better job of the Bilt Hamber when I strip the rear down again for poly bushes
Front end rust tidy
New soft top (although I might leave that to the professionals)
And then probably loads I haven't considered - while keeping it as stock as possible
WesOCP
Quote from: Joesson on May 13, 2021, 15:11If that is a Coolparts radiator the design has changed from the one I bought a few years ago. Mine has a small "pipe" on the top of the nearside vertical header that was blanked off as it was of no use.
Ebay job from a company in Ilford
https://www.ebay.co.uk/itm/150561877372
I paid £34, they seem to have gone up a bit!
Coming along nicely.
(Luckily no one should ever see those brake lines!).
WesOCP
Only one slight detour so far - better half didn't see the concrete post in a car park.
Easily done but an easy fix
Zxrob
Wow, you are
1. getting stuck in
2. unlucky with the bodywork :(
Rob
Adventure before dementia 😁
puma2
 :) you are doing so well :)
now gutted for you as paint work is upsetting to see and then deal with :(  :(
WesOCP
Managed to get a few bits done over the weekend - new 4ch amp is now powering the Focals & a bridged channel for the sub, after lots of measuring & some contortionism unbefitting of a man of my advancing years.
Just tucks away nicely under the unused drinks holder & ashtray
and got the Das-6 Pro out for some HL cleaning - (offside is the 'before' pic) Bob's helping as usual
Next weekend it'll be some much needed cleaning & waxing, then probably the same for the car
