Facelift rear light condensation
Started by Craigjm, January 22, 2023, 11:33
Craigjm
One of my rear lights has quite a bit of condensation in it. I notice on the mr2 Ben website that there is a gasket kit available which suggests they come apart. Does anyone know how they come apart or has done it?
https://www.mr2roc.org/index.php?topic=72956.0
Read the above.
To seperate the lens from housing press the black housing 'inwards' from the lens tabs. Having the unit warm rather than Winter temperatures should make things easier.
@J88TEO - did you get the 4mm diameter & try it?
Edit-: topic beeing discussed on f'book.  One guy saying he's successfully used 5mm diameter.
J88TEO
Yes I did. A bit too thin. I would go for the 5mm ones.
