oh dear there goes teh gearbox
Started by markiii, May 7, 2007, 19:05
#275
Quote from: "aaronjb"Before we'd gone anywhere I ran through the gears with the engine off, clutch engaged - all fine, 1st through to reverse engaged perfectly.
Started the engine, clutch down and 3rd would not engage.  I mean, not at all - no grinding, no whining, just will not push into gear no matter how hard you lean on the stick..
Run through some other gears and back to 3rd and it dropped in.
Are you 100% sure you don't have air in your clutch line? When I had issues with bleeding the clutch, this was exactly what I had. For some reason the 3rd had that issue and no other gear, sometimes it did that, sometimes it didn't. And it always worked just fine when the engine wasn't running.
Might wanna try to bleed the clutch before dismantling the gearbox.  s8) 8) s8)
#276
Quote from: "Tem"Might wanna try to bleed the clutch before dismantling the gearbox.  s8) 8) s8)
Mark has a pressure bleeder as well Phil, only takes 2 seconds, could be worth a go
don't know why it should suddenly be an issue
but happy to give it a try
#278
I was using a power bleeder too, but for for some reason it didn't get all the air out before I tilted the car here and there.  s:? :? s:?
Maybe I was just unlucky, but I think it's worth a try. It's just so much easier than redoing the box.  s8) 8) s8)
#279
Quote from: "rtbiscuit"still waiting on those pics nigel   s:wink: :wink: s:wink:
That's Stu and Rich enjoying a nice mug of MT-90 Nice!  s:lol: :lol: s:lol:
And if you look at the next one, you get an idea of why Stu's box might have expired.
Okay, you might not, but his 2 was moving quite rapidly at this point and the horizon was approaching exponentially!
(Pic taken on phone cam on IMOC outing)
rtbiscuit
#281
yeah baby, now thats what i'm talking about!   s:lol: :lol: s:lol:
current car: Jaguar XKR
Previous cars:
#282
thats great Nige  s:D :D s:D  , that last one was a fantastic day out, i loved it when we got up on edge and i just fell into that place between reality and rush when the adrenaline gets pumping  s8) 8) s8)  why i joined this great club of ours
#283
Right - back to the subject of getting the J-spec final drive ratios on a box that didn't originally come with them..
According to the diadrawagrams I'm looking at, the parts involved are these (bolts are included as they could well be use-once):
P NO        QTY DATE    DESC
41221-20350 01 (9910- ) GEAR, REAR DIFFERENTIAL RING
33321-20140 01 (0208- ) SHAFT, OUTPUT
90105-11040 08 (9910- ) BOLT (FOR REAR DIFFERENTIAL RING GEAR SET)
So according to that, the only thing that's actually different is the output shaft - the diff ring gear is the same through all years... meaning you ought to be able to use your existing ring gear - it made no difference if I was looking at 5spd or 6spd years..
I'm still waiting for my parts to rebuild my car, but here are some pics about the last step.
Removed Clutch and Flywheel:
Whole system:
Clutch pressure plate:
Dead stock clutch disc RIP !
Flywheel:
 s;) ;) s;)
any date for yoiur box arriving now Ben?
#286
Crikey, I'm amazed that clutch was still doing anything!
#287
Quote from: "aaronjb"Crikey, I'm amazed that clutch was still doing anything!
hey there must be at least 0.002" left on it!
he must drive like stu   s:shock: :shock: s:shock:
Quote from: "markiii"any date for yoiur box arriving now Ben?
UPS collect was planned for... yesterday, but today, no update on the tracking >_< I mailed UPS to ask manchester depot where/when is planed now...
I wish I'll have the box tuesday/wednesday fingers crossed...
LoL ! I had my clutch sleep since last october, i'm not surprised with this :p
Quote from: "markiii"he must drive like stu   s:shock: :shock: s:shock:
  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
#290
oi!, ya bugger!!
**grumble, grumble, wanders off muttering to himself**
#291
Just double checked the part numbers I posted earlier to make sure I'm right, now that I have some new data..
2003 on J-Spec 6spd:
33321-20140 - Output Shaft
41221-20350 - Ring gear
Pre 2003 UK 5spd
33321-17020 - Output Shaft
41221-17040 - Ring gear
03+ UK 6spd
33321-17030 - Output Shaft
Incidentally, I had to look the J-spec 6spd up as an Australian 6spd SMT - however the shaft and ring gear are identical regardless.  Incidentally, those part numbers are also applicable to the ZZT230 (1ZZ Celica) for all territories - which confirms they are the right ratios (based on the Excel sheet earlier).
So, now you know what to order  s;) ;) s;)
Oh, and assuming the Oz 6spd SMT has the J-spec ratios throughout, here's the other gears that are different:
33423-12040 - 3rd (driven)
33034-12131 - 3rd
33035-20171 - 4th
33422-10040 - 4th (driven)
Of course if you're in there you might as well replace the synchros too..
since your looking any confirmation that those parts are the same for teh US 6 sp smt?
#293
I can't seem to find the US model code in the data that I have  s:( :( s:(  I think I might need someones chassis number to be able to confirm whether or not I have the US territory data for the Spyder
#294
good point about the synchro's, so the shopping list will be a full set of bearings, a set of synchro's plus the gear change components right?
#295
Yeah - but hell if you're doing that you might as well get the needle bearings (not sure if you included those in your bearings bit earlier as they're not the bearings that collapse - but they do wear), spacers and at least 2nd & 3rd gear synchros.
Oh - and the single use snaprings & nuts.
Yeah, that's a lot of parts  s:) :) s:)
I'm assuming thatgearbox blokey will replace anyting neccessary when building teh box
#297
Quote from: "markiii"I'm assuming thatgearbox blokey will replace anyting neccessary when building the box
we hope  s:roll: :roll: s:roll:
Yeahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
here's my new 6MT gearbox to replace my broke 5MT :p
I worked about 2 hours to have it look as this  s;) ;) s;)
but i'm really proud how it looks now:
Next step tomorrow: install this, my clutch, flywheel, header, cat... 1 month without my MR-S it was long....
 s:) :) s:)
ps: BIG THX TO Markiii, who helped me A LOT with the dealer, calling him 2 or 3 times, offering me to ship me the box, and more. I'm really recognizing for all this help Mark, don't hesitate if you I can help you about anything  s:) :) s:)
Ben
no probs, gald it arrived at last.
geez, is that just polished? have you sealed it with anything to stop it corroding again?
