Headlights
Started by worzy, July 11, 2007, 18:11
worzy
Hi Guys,
I have recently took my head lights out and sprayed them to match the car, like a fool i ripped them out before marking where abouts the beams were. Now i dont know the hight of the beam.
Could anyone help me out with this at all please?
It would be greatly appreciated if someone could measure how high up on the wall (or garage door) the beams are and the distance you are away so i can set mine up properly.
Thanks,
Ben.
Quote from: "worzy"It would be greatly appreciated if someone could measure how high up on the wall (or garage door) the beams are and the distance you are away so i can set mine up properly.
Generally the beam should lower 1%. Which means 10cm on a 10m distance.
But somehow I recall the lights had 1.5% marked on them. On the top. Better check that marking first.
firepower
why not go to a garage that has a beam tester and have it set correctly that way you know you will not be blinding oncoming traffic   s:D :D s:D
01 tte turbo, sp exhaust and down pipe, tte springs 190hp more power soon ? 205lb/ft
1/4 mile 14.6 s @ 90 .55 mph  ( at drag strip )
worzy
Thanks guys,
I will ring round tomorrow and see if the local garages can help with that.
enid_b
any MOT station would be able to help you out with that chap.
E
