Will these alloys fit?
Started by alij100, June 27, 2012, 22:17
alij100
I'm after some new alloys and like the OZ superturismo alloys. Iv found a set which are 16+7 4+100 et37. Would these fit?
alij100
Anyone?
Standard specs for wheels
As you can see from the above link the offset (et) is 8mm difference. Which means the wheel sits further under the arch by 8mm
Also, to preserve the tyre stagger you'll notice that the depth of the wheels front to rear have a difference in depth 6" to 6.5" (Pre FL) or 6" to 7" (FL). So your front tyres would be stretched by an extra inch to fit on the wider rims.
I have that size and offset OZ on the front of mine .... no problem   s:D :D s:D
You will need to up your front tyre width to 195 though, as long as you keep 215 on the rear you should be fine
alij100
So theses alloys will fit. Thank you for replys guys.
