Dev's famous covers - do they all go like this?
Started by AckersMR2, July 30, 2012, 20:18
AckersMR2
Ok so most of us have fitted these so most of your should have an answer?
Do they all go like this after 4 months?
To be honest in the light I thought the paint was a little thin in places when I got them but didn't say anything and although I do like to keep the car clean I only use car shampoo and a lambs wool mitten, not a scouring pad and a screwdriver!
Now removed, the keyhole looks better  s:( :( s:(
My only car is a Ducati
Mike_V
Yep, thats normal, they are made of rubber so they flex and need repainting every now and again.
2004 Red edition in Sable.
AckersMR2
Quote from: "Mike_V"need repainting every now and again.
Or every 3-4 months apparently  s:? :? s:?
Mine are fine after a couple of years.
Chris H
Quote from: "life of bryan"Mine are fine after a couple of years.
Same here....  s:) :) s:)
Mike_V
After 12 months I've had to redo mine once.
DannyN
There have been a couple of revisions from Dev
[/size]
AckersMR2
Quote from: "DannyN"There have been a couple of revisions from Dev
what in the last 4 months?
Quote from: "Chris H"
Mine too, after a couple of years I just replace them.
jjr197
2 years and no problems with mine.
"If you're driving with the top up, the storm outside had better have a name!"
DannyN
Quote from: "AckersMR2"
No I meant over the years.  He has refined the process to make them last longer which doesn't seem to have worked for you
[/size]
JudoKilli
Mine are looking cracked after a year or so. No paint peeling as of yet though.
2 of the left
Never got them - Only way into my 2 is by key!!  s:wink: :wink: s:wink:
SI VIS PACEM PARA BELLUM!!
I had them on the MR-S about 3 years and they had a little cracking in places but no peeling. New ones I've had since January and they're still good as new.
lemans
Mine are still good after several years, with maybe a hint of fine cracks just appearing this summer.  I noticed mine after coming back from France when my car was left out in the sun a lot.  Car is normally garaged so hot sun could be making the rubber flex and paint crack. I got worse cracking on my front bumper last year after a holiday in Italy, so I would say the sun could be a big factor in the cracking on your keyhole plugs.
Daryl
Facelift Black MR2 with red leather interior. Hardtop, rear brace, SP body brace, TRD short shift, Mongo\'s,  Dev\'s & SP Turbo - 238bp, 220lbft.
AckersMR2
Quote from: "lemans"so I would say the sun could be a big factor in the cracking on your keyhole plugs.
If we'd actually had a summer yet this year i'd be inclined to agree with you  s:lol: :lol: s:lol:
Quote from: "lemans"Mine are still good after several years, with maybe a hint of fine cracks just appearing this summer.  I noticed mine after coming back from France when my car was left out in the sun a lot.  Car is normally garaged so hot sun could be making the rubber flex and paint crack. I got worse cracking on my front bumper last year after a holiday in Italy, so I would say the sun could be a big factor in the cracking on your keyhole plugs.
I'll let you know on that theory when I get back, not had a day below 30 degrees so far   s:wink: :wink: s:wink:
dcod
Mine have gone like that after 4 months. Thought I was the only one. The sun most certainly didn't do as they went like that during the 3 months of cold and rain.
MisterK
Had mine since January & still like new.  Mine are Astral Black & car kept in a garage.  Is it a specific colour that has the problem?
dcod
Quote from: "MisterK"Had mine since January & still like new.  Mine are Astral Black & car kept in a garage.  Is it a specific colour that has the problem?
Mine is black.
Dev is a nice guy but I don't think his products are up to standard. I've not got keyhole covers as i was happy with the lock, but if it is sprayed rubber then it will always crack and flake. If it were to be more lasting then it should be at least a plastic.
Mine may be an earlier version and they're made of thermoplastic (injection molded), there is a bit of flex in them, but when they're on the car there should be no movement to cause the paint to degrade. The only reason they go like this is because they get washed and polished .... but then if you're looking after your car that's recommended.
With you on that rbuckingham, nice guy but I've lost faith in his products. Saying that I'm more than happy to refresh my "covers" annually, for the price it's ok.
Cracking often occurs if plasticizer isn't used in the paint mix.
lemans
Quote from: "dcod"
Mine is black.
Mine are black too. Must be the best colour then  s:twisted: :twisted: s:twisted:
Daryl
andibell
Had mine for around a year, they're the moulded plastic ones too.  One has a slight mark, which was of my making, but apart from that they're great condition.  My car is kept in the garage and not driven too frequently though.
Curse your sudden but inevitable betrayal
