Need new toe arm and bolt!
Started by nolivert, February 20, 2013, 13:40
nolivert
So I've managed to replace my cross member, even without moving the exhaust, I have learnt some new swear words, and had a bugger of a time removing just one of the rear arms. Anyway the long and short of it is I need a new offside rear track arm (part no: 48730-17060) and camber bolt (part no: ASAP 48190-32010).
I think this is officially called a Toe adjuster arm, the one with the ball joint on the end. If no-one has one, does anyone know where I can get a new one? Also need the camber bolt for that side (drivers side).
Many thanks in advance
Nick
You can try CTP on here in the affiliates section
