ABS light.
Started by Mike_V, June 29, 2013, 17:01
Mike_V
Finished working on the front end of the car today and took it out for a "shakedown" everything was fine until I heard what sounded like a crack behind me followed by the ABS light coming on, eased the car home, to the offside rear wheel off and everything looks ok. Any ideas?
2004 Red edition in Sable.
redarrow
Check all the abs fittings, might be dirt or crap just fell of the
 lead and the lead is know lose
Undo it then use wire brush cleanup,
Then re connect.
Then battary off 20 mins to reset ecu.
Regards john/ redarrow
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
