Headlight adjusters
Started by Pierce, September 27, 2013, 20:41
Pierce
On a 2000 Roadster there are two adjusters per headlight,lets call them upper and lower.Which is up and down and which right and left? For the former is it clockwise or anticlockwise for up and for the later for right? Jeff
redarrow
There no point knowing because your never
Get it spot on , use a garage only  a fiver and
Free on mot day.
 Plus if you do it your self you might
Think it ok and blind on coming drivers.
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
Pierce
But having fitted a new light I would like to get it approximately correct and not dazzle people.
redarrow
At the top of each light, there's a sort of reversed castellated nut. Basically you stick a Phillips screwdriver into the castellations and turning it moves the light up or down.
A "simple" DIY test is park the car on absolutely flat ground facing a wall, garage door whatever exactly 3 metres away from the headlights. Measure up on the wall where the same height is, then the beam should be 21mm below that. This applies to pre03, not sure about post 03, which has different lights.
