Inphase USW8
Started by lamcote, March 8, 2018, 17:09
lamcote
Does anyone have any thoughts on whether the USW8 subwoofer is any good?
I would be intending to mount it under the driver's side dashboard.
Well I'm very pleased with my usw10, so can't see why the usw8 would be a disappointment
Justin.D
+1 on the USW10. Mounted under the steering column
Click for my Readers Ride
lamcote
Thanks, I've ordered a USW8.
I don't suppose you can remember what size nuts fit on those bolts next to the OBD2 port under the dash?
Edit. I think they're 6mm threads.
Quote from: lamcote on March  9, 2018, 12:16
The majority of fastenings up under there are M6, just be mindful of the end of the brake lever when you're placing.
lamcote
Justin.D
It's also worth getting nyloc nuts, or using threadlock as they 'can' rattle loose - I found out the hard way. Too much bass from the sub makes loose nuts  :D :D
Quote from: Justin.D on March 10, 2018, 06:12
Absolutely! And if not, put in a very thick rubber washer and a locking washer
lamcote
Will do, thanks again guys.
Do I need to use (splice off) the blue power aerial wire to switch the sub on when the HU powers up?
Justin.D
Quote from: lamcote on March 10, 2018, 12:58
Depends. If you are using High Level Input (ie speaker wire to the powered sub) then no - The sub will pick up speaker signal and automatically switch on and off
If you are using RCA (the preferred method) then yes, you will need the blue remote turn on too
lamcote
Great thanks, yes I'll be using RCA.
Thanks everyone for all the assistance.
smarty72
Been thinking about fitting something similar since I got my car.
I have a Kenwood aftermarket DAB HU that I've fitted last year, would an active sub come with all the necessary wiring and instructions for an 'average joe' to fit themselves??
current: Astral Black FL
Ex: Forest Green 2003.
Quote from: smarty2072 on April 28, 2018, 19:16
Depending on which Kenwood HU you've got it's just a matter of getting some RCA cables and plug and play if you went for the Kenwood sub.
smarty72
Quote from: Call the midlife! on April 28, 2018, 19:52
Ah, that seems simple enough then - I fitted a DPX406 which I think has RCA output.
Will be adding one to my 'wish list'.
Quote from: smarty2072 on April 28, 2018, 22:26
Yup. 2 RCA preouts and Low Pass filter, good to go!
Quote from: Call the midlife! on April 28, 2018, 23:23
mr9
Where did you get the metal brackety strip? Can't find any around
@mr9 "metal brackety strip" please tell me this was your eBay search. :)
A Cuprinol eBay search wins all! :)
Quote from: mr9 on May 17, 2018, 21:45
It's stainless builder's banding from Screwfix.
Quote from: Call the midlife! on May 17, 2018, 22:38
https://www.screwfix.com/p/sabrefix-builders-band-stainless-steel-20mm-x-9-6m/59863
Obviously others are available [emoji38]
